2nd choice would be Rally IIs in ANY configuration.
3rd choice would be Center Line Auto Drags (brushed finish, so no polishing) 4th choice polished aluminum slots Bigs and littles if possible. |
Except what was on most cars in the mid to late 60s which is the cragar SS . Not sure I like them
On a classy car like a GP and dint like the American torque thrusts that’s was an early 60s wheel I did see a really sweet black w white interior and white half roof in CT last week w ralley II and (going by memory) red center caps that looked outstanding. Such a classy looking ride. I’m Not a keep it all stock kinda guy I like both ways but on the GP I like the ralleys w redlines or white walls it’s just looks classy
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
![]() Ironically, I would move the Torq-Thrusts down on my personal preference. I'm not a huge fan, though I know many are. I run a set of Cragar Eliminator's on my 72 LeMans GT, but not sure they make those any longer. Well, not in 15" anyway. I run Wheel Vintiques Rally II's on my 71 GTO, and you can get various sizes and back spacing from them. Chrome hoops if you like too (on my 71) Both of my 67's & 74 Bonneville run Rally II's. And let's not forget Ansen Sprint, or as they say, "slot mags." The modern version may be US Mag's or the like. If anything says 1970's to me, it's slot mags. I have a set on my 2005 GMC Canyon. They look great to me on anything from my truck, to a vintage GTO/Grand Prix or even a Bonneville. Slot Mags are hard to beat to my eye. I guess the answer really is, "whatever you like." Everyone else will always have a diff opinion.
Eric Mitten '74 Bonneville 4dr Sedan (455/TH400/2.93 open) '72 LeMans GT (455/M-13/3.23 [8.5"] posi) '71 GTO Hardtop (400/TH400/3.07 12 bolt posi) ‘71 GTO Convertible (455HO/TH400/3.23 posi) '67 GTO Coupe (455/ST-10/2.93 posi) Deuteronomy 8:3
To me the TT's and Centerline AutoDrags do not carry the style theme that Grand Prix's should have and frankly are far too common.
The 17" R2's do and have a far superior selection of rubber. |
I like the Rallye 2's, 15x7 up front and 15x10 in the rear. If you want the weight savings Convo-Pro's. Not a fan of the Torque Thrusts on later cars. As mentioned Torque Thrusts scream 1960's...... That GP body style was used from 69-77.
So does anyone make Rally 2 in aluminum that's 15x10? Year one makes 17" ones
I don't believe so -
the thing about those GPs is the Year One 17" Rally IIs look really good on them unlike some other models where they look too big.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
I'd go with the 17" but no real good street/strip tires in that size.
If it were mine, I would find these.
Yeah, I have '17's and even the street tire selection is slim pickin's.
Triple Black 1971 GTO |
This is Summit's listings winnowed down by wheel size. I would hazard to guess they carry more 14 and 15 inch stuff than say Tirerack being Summit is more race oriented. Note 17" is almost the most popular size: Wheel Diameter 18 in. (3,232) 17 in. (3,226) 20 in. (2,335) 19 in. (2,035) 16 in. (1,970) 15 in. (1,861) 14 in. (721) 21 in. (530) 22 in. (466) Filtered by competition tires. ie. slicks, track only: Diameter: 15 in. (330) 17 in. (133) 18 in. (133) 20 in. (110) 19 in. (88) 16 in. (84) 13 in. (20) 21 in. (14) 14 in. (9) 22 in. (3) and filtered for Summer only, UHP tires: Diameter: 19 in. (572) 20 in. (551) 18 in. (439) 17 in. (185) 21 in. (171) 22 in. (86) 16 in. (37) 23 in. (11) 15 in. (9) 24 in. (6) Note how 15" are almost nonexistent and no 14's at all - even for Honda sizes... Last edited by Scarebird; 10-14-2022 at 04:16 PM. |
no, newer muscle runs 17 and up and have no issues hooking up.
I believe you need to define the task you wish your GP to do. I cannot say the a GP would be my first choice in street/strip platforms. I believe a true street car has the reliability of a daily driver but with bit more grunt/handling chops. 60 foot times would have little to no say in the equation unless more than 10% of the miles was at a dragstrip. |
I first noticed a 69 GP when I was in high school. It had aluminum slots on it, and looked real sharp!!!
I once owned a set of U.S. Mag aluminum slts. Absolute best looking aluminum slot wheels made!!! They are being made again. I'm tempted to buy some for my TA. Although I already too many complete sites of wheels I like, already. For future use...
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
So I'm confused on the backspacing of the wheels listed on the American Racing site. What is offset?? Some of the wheels they list as 3.77 backspacing with 44mm offset. Guess I'm confused.
American Monocast or Rally II’s
Let's make welfare as hard to get as Veterans benefits! |
#38
What’s on the back now they are retro now and look great on just about anything.
#39
BS will change based on the width of the rim in question, so if your changing rim width's, your desired BS will change, but offset won't. For instance, if you have a 15x7" rim with 4.25" BS (6mm offset) and want to go to 15x8's, you would need to have 4.75" BS to have the same 6mm offset to position the tire in the same place in the wheelwell. This chart will probably help you.
| The Following User Says Thank You to The Champ For This Useful Post: | ||
#40
https://www.nittotire.com/competitio...g-radial-tire/
73 T/A 455, 4speed |
