Old 01-22-2023, 04:32 PM
Sirrotica's Avatar
No matter how hot the interior gets with the heater on. it still beats walking.
As I found out trying to get my dirt track cars to run cooler, every little bit of increased coolant capacity helps an engine to cool longer before it hits the critical point. In my quest to keep race cars cool, adding an extra gallon of capacity makes a great deal of difference.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #42
Old 01-23-2023, 12:53 PM
Originally Posted by TCSGTO View Post
It works in the movies. Watch the chase scene in the 1971 movie Dual where Dennis Weaver plays a businessman terrorized by an 18 wheeler while driving thru the desert in his Dodge Dart.
Oh that was a classic!
Stupid quesiton; if the temp gauge goes into the danger zone in traffic are you better off to pull over and shut her down to cool off or put on the heat and try to get moving?
  #43
Old 01-23-2023, 05:25 PM
70GS455 70GS455 is offline
Just run the blower fan backwards so the hot air goes outside the car instead of in the cabin. Just kidding, won't work that way but if it did....
Sent from my SM-T817V using Tapatalk
  #44
Old 01-23-2023, 06:03 PM
freebird69's Avatar
freebird69 freebird69 is offline
In my case if I can get moving my temp goes down pretty fast but if I can't get going I will find a place to pull over and pop the hood or find a side street to get up some speed. Using the heater does help but not enough because it doesn't stop the temp from rising but only slows it down.
The Following User Says Thank You to freebird69 For This Useful Post:
  #45
Old 01-23-2023, 08:58 PM
Schurkey Schurkey is offline
It's time to diagnose and fix that situation.
  #46
Old 01-29-2023, 12:24 PM
zippy's Avatar
zippy zippy is offline
My 455 runs cooler when I block off the Heater Core. About 7*F cooler. I have a hose pinch I use in summer, to stop flow to it. Spring and fall I use for heat. But, the heater core is just a constant bypass. From head, through core and back to water pump. In summer, there is no cooling being done by core. Its just recirculating some hot coolant.
Dan Pesonen
"If it ain't broke, modify somethin till it is"
  #47
Old 01-29-2023, 08:21 PM
yellow1098's Avatar
yellow1098 yellow1098 is offline
I ended up by passing mine after this ordeal and it’s running cooler now than before it was going through the leaky heater core
