Old 05-06-2023, 10:48 AM
jhein's Avatar
jhein jhein is offline
I have the TKX with 2.87 1st/.81 OD. 467 cid, 3.31 rear, 27 inch tire.
I totally respect FJs comments and I'm sure you would not go wrong with his advice. But, I think it depends on how you drive the car. If you do a fair amount of driving, cruising at 75 or more, then the .68 OD is probably a good idea. If you rarely cruise that fast for prolonged periods then the .81 would be as good or dare I say a little better. The roads I drive on are 55 mph roads. At 65 mph I'm at like 2100 RPM and I can do that all day long. 75 mph is around 2500 and is still very comfortable. I think if I had the .68 OD I would use it less, but maybe I'm wrong. But, I'm very happy with my overall gearing.
You could also do the 3.27 1st/.72 OD. But even with the 2.87 1st, traction is an issue so I'm not sure how the 3.27 would do.
