Old 08-12-2023, 03:43 AM
64speed's Avatar
64speed 64speed is offline
The super turbos with an X pipe is as quiet as you can get without sacrificing power. At wide open throttle, they still are kind of loud, but no where near other mufflers I've run.
What do you mean by 'cold natured'? Like it doesn't fast idle and warm up without playing with the throttle?
Just to say, you shouldn't drive it 'cold', always let it warm up some, 160 coolant temp min, and never hammer it with cold oil.
Exactly it doesn’t fast idle and I have to keep my foot on the accelerator to keep the rpm’s up from about 500-600
  #1742
Old 08-12-2023, 10:42 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
The car looks and sounds great! Glad to see you got it back together. What length/brand mufflers are you running now?
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
  #1743
Old 08-12-2023, 11:21 AM
64speed's Avatar
I think my local muffler shop carries Dynomax. I’m gonna get them if they have them .
  #1744
Old 08-12-2023, 12:40 PM
NeighborsComplaint's Avatar
Yeah, you will need the longer case mufflers to quiet it down. For as little as the shops charge, it's not worth it to lay on your back and saw pipes off.
Triple Black 1971 GTO
  #1745
Old 08-12-2023, 12:59 PM
64speed's Avatar
I think it’s got 14 inch case on it now, I may be wrong, it’s the 3 inch venom 300
  #1746
Old 08-12-2023, 01:23 PM
Yeah, those aren't what would be considered 'quiet' ! Heheh!
As yes, the objective is to use as large a muffler case as possible to keep it on the quieter side. If the shop carries the mufllers, they can determine which is the largest that can be fitted.
IMO, as quiet as possible without a performance hit is the best goal. You don't want to draw attention when you hammer it is my motto.
  #1747
Old 08-12-2023, 01:27 PM
Get the 20” long 17749 Dynomax Super Turbos.
I have used them on a couple of my ‘64s and they’re quiet enough during normal driving but have a nice muscular sound when you hammer it.
Bonus they flow better than the short 17734 mufflers.
The Following 2 Users Say Thank You to b-man For This Useful Post:
  #1748
Old 08-12-2023, 01:28 PM
geeteeohguy's Avatar
Agree car is too loud but is gorgeous and done in excellent taste. Hope it stays reliable and issue free!!
Jeff
The Following 2 Users Say Thank You to geeteeohguy For This Useful Post:
  #1749
Old 08-12-2023, 02:06 PM
What carb again? Gotta fix the fast idle, it's not hard.
Definitely use as large a case muffler as possible.
On another note, no pun intended, but tips that point to the ground also help quiet it down some. Maybe go to the side splitters, and angle them down some. That would help.
You have a full 3" system? You could go to 2.5 tail pipes, that would help too, and very little to no performance hit.
  #1750
Old 08-12-2023, 03:37 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is online now
Car looks and sounds great, hopefully the 3rd time is the charm
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
  #1751
Old 08-13-2023, 07:31 AM
64speed's Avatar
Drove it a lot last night and it jerks at low speed. Where should I start?
  #1752
Old 08-13-2023, 12:33 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Maybe start by to dialing in the combination, working out the bugs and enjoy the car for a while. I didn't read the part about why the mufflers need replacing but if this was my project I'd hold off on that for a while.
Most likely the low speed bucking is carburetor related.
Go fast, see Elvis!
  #1753
Old 08-13-2023, 12:44 PM
64speed's Avatar
I’m trying to enjoy it but it’s too damn loud LOL
  #1754
Old 08-13-2023, 02:26 PM
Check your fuel pressure.
  #1755
Old 08-13-2023, 07:19 PM
The Champ's Avatar
The 20" 17749's fit a '64 A body just fine.
My '64 GTO with the 20" Super Turbo's - and they are quiet enough so I can hear my stereo with the convertible top down.
You already have the 3" pipes, so slipping in the 20" case 3" 17769's should be an easy fix to your problem.
ID:	618087   Click image for larger version
The Following 3 Users Say Thank You to The Champ For This Useful Post:
  #1756
Old 08-13-2023, 07:53 PM
tom s tom s is offline
20in case and 2 1/2 tail pipes.Tom
  #1757
Old 08-13-2023, 07:57 PM
Gach's Avatar
Gach Gach is offline
Just think now you’ll be able to listen to Johnny Cash, wink
The Following User Says Thank You to Gach For This Useful Post:
  #1758
Old 08-13-2023, 09:08 PM
64speed's Avatar
Life ain’t easy for a boy named Sue
The Following User Says Thank You to 64speed For This Useful Post:
  #1759
Old 08-13-2023, 09:15 PM
Gach's Avatar
I can remember in Junior high, 63-63, dresses all in black, like Johnny Cash. LOL
In 1952 I was 6 years old, Hank played Live at the calabrese club, here in Westerly RI. I was 6 years old, I went to see him with my uncles and my grandfather. I will never forget it. I remember it like it was yesterday. At my uncle funeral 40 years later the played all of Hank Williams songs, I sat there in tears.
The Following 2 Users Say Thank You to Gach For This Useful Post:
  #1760
Old 08-13-2023, 11:27 PM
blueghoast's Avatar
Mine jerks at low speed when I'm lugging the car down thats just
the camshaft jerking you around. Ya just got to get use to driveing it
Don't lug it down so much cause you've got a rowdy cam there it
sounds like to me. This is a stick car right?
GT
