Old 06-08-2024, 12:05 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
Default 1965 389 What's it worth?
Hey guys I have a 65 389 that I pulled out of my 67 Firebird. I don't anything about the engine other than it's been trouble free for the 22+ years I've owned the car. It does have oil leaks and I did replace the timing chain about 20 years ago. Other then that she's a runner. I had it dynoed back in 2015 where it pulled 273.7hp / 358tq. I'm running edelbrock RPM intake Holley 750 and protronics ignition. I do have the cast iron intake but I don't know if it's original. https://youtu.be/UmKDccwIJpU
Name:	436446864_3615814518682257_2290687278673478628_n (Large).jpg
ID:	634972   Click image for larger version
Name:	436568367_348321308002552_7133344963241470161_n (Large).jpg
ID:	634973   Click image for larger version
Name:	441973406_1145352730043728_2138573903190587276_n (Large).jpg
67 Firebird Convertible
Old 06-08-2024, 02:25 PM
That is a YE code 325 hp 4-barrel 10.5:1 compression 389 with #76 heads from a big Pontiac equipped with a TH400 automatic.
Not particularly valuable because it’s not a GTO 389.
The 389s really aren’t sought after unless they’re from a GTO, and even then it’s the manual transmission engines and especially the Tri-Power engines that people are looking for.
Maybe $500 because it’s a good running engine, but a leaker as the majority of older 389s are.
If it were mine and I had the room I’d keep it as a good running spare just in case.
The Following 4 Users Say Thank You to b-man For This Useful Post:
Old 06-08-2024, 03:09 PM
77 TRASHCAN's Avatar
Some one that has a 69 or earlier engine in their car could use it as a temporary replacement to get their original engine redone. From my knowledge, the motor mounts should work from 69 to 65? Bart?
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
Old 06-08-2024, 03:31 PM
You are correct.
