I thought the problem was with canceling cam not making contact with the plunger in the turn signal switch. It barely makes contact. the problem was with the green wire coming from the horn relay to the semi circle plug under the dash. The terminal was a bit corroded and the connection wasnt that good. I cleaned it up and its working great now. Just a pain to trace it back to this point but feel great now that my entire electrical system is working perfectly after having the whole car apart. No lost grounding issues! they can be a real PITA!
thanks again to all. |
If anyone needs it, here's a good diagram for the assembly. I thought I'd lost it during my XP reinstall but just found it this morning..... after looking all week. Included is the Assembly sheet for a Grant steering wheel and the horn.
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
TODD Last edited by pmdclassics; 07-09-2024 at 09:31 PM. |
Is there a spring in the column assemble as I marked in this diagram??
TODD |
