SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 11-05-2023, 07:34 PM
65gto69's Avatar
65gto69 65gto69 is offline
Default CENTERFORCE DXF CLUTCH & PP F/S
Used centerforce DFX clutch and pressure plate. This is 11" with 26 spline, still looks like it has a lot life in it.
$250.00 or make offer plus shipping
Thanks,
Mark
Name:	CTRFORCE DXF 26SPLINE 11-01.jpg
ID:	622874   Click image for larger version
Name:	CTRFORCE DXF 26SPLINE 11-05.jpg
ID:	622875   Click image for larger version
Name:	CTRFORCE DXF 26SPLINE 11-04.jpg
ID:	622876   Click image for larger version
Name:	CTRFORCE DXF 26SPLINE 11-02.jpg
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 11-06-2023, 01:25 AM
jotrout jotrout is offline
What t/o bearing should be used? Thx
Old 11-06-2023, 08:55 PM
65gto69's Avatar
I would contact Centerforce and let them know what clutch and pressure plate you have and what car this is for and they should be able to tell which throwout bearing should be used.
If using on a traditional Pontiac engine, I would use a throwout bearing for setup which should be your typical GM throwout bearing.
Thanks,
Mark
Old 11-12-2023, 09:11 PM
65gto69's Avatar
to the top
Old 11-25-2023, 11:04 PM
65gto69's Avatar
bump
Old 12-30-2023, 10:16 PM
65gto69's Avatar
bump
Old 01-26-2024, 01:25 PM
65gto69's Avatar
bump
MAKE OFFER!!!!
Old 03-18-2024, 12:15 PM
65gto69's Avatar
bump to top
Old 04-24-2024, 12:50 PM
65gto69's Avatar
BUMP TO TOP
Old 07-24-2024, 12:30 PM
65gto69's Avatar
bump to top
Old 07-25-2024, 02:03 AM
blueghoast's Avatar
Originally Posted by 65gto69 View Post
bump to top
How much power will this setup handle ?
GT
Old 07-25-2024, 12:16 PM
65gto69's Avatar
https://www.centerforce.com/i-304995...-disc-set.html
Here is the link to Centerforce site for this setup. It shows holds up to 700 lb/ft torque
Thanks,
Mark
Old 07-29-2024, 08:32 PM
65gto69's Avatar
SOLD!!!
Thanks P.Y.
