Does anyone make a 2" roundport headers for a 1975 Trans Am? Dougs offer a set from 70 to 74. Only a 7/8 for 75 up.
I wouldn't know why they wouldn't work in 75 and up?
If wanting pipes all the way back to rear it may be hard to do. But if open headers, should work?
| The Following User Says Thank You to johnta1 For This Useful Post: | ||
Hooker does, they advertise them as 70-74 due to the round port heads. I think the PN. is 4202
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
As Paul said Hooker 4202. Fit my 78 and the 79 Camaro with the IA motor in it. And IA block needs a little massaging esp on #1 to clear the block and freeze plug area.. May need a dimple near the rear lower A arm bracket on the frame. Some sets near the oil filter. one set i had was real bad at the oil filter.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
| The Following User Says Thank You to Skip Fix For This Useful Post: | ||
Why do you need 2" headers ?
To make good use of such and produce the highest average torque numbers your Exh ports would have to flow 225 cfm@ 28".
I have them on a 72 Firebird with an E-head 400 block stroker, fit great overall with no problems getting a full size pontiac oil filter in/out.... only complaint is that they do hang down lower than most other headers due to the big tubes & collectors. |
![]() I have Hooker 4202’s on my 70 TA with Flowmaster 4-2-1 collectors. They seem to work well and they give the car a very unique sound. I don’t think Flowmaster makes them any longer. The set on my car are 2” primary. I have a NOS set of Flownaster 4-2-1 in 2 1/8” that I bought new years in my garage. I planned on using them for a previous build and never got around to it.
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
http://www.wallaceracing.com/header_length.php
A tid bit. Some calculators, formulas and performance recommendations use the tube's INSIDE diameter. If that's the case you would need to subtract twice the tube's wall thickness from the outer diameter. If so that header material might be 16 gauge (.062") or 18 gauge (.049"). One example here: https://www.discountmags.com/magazin...is-issue/12912 .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
I had GP headers copy a set of the Hookers in SS!
| The Following 2 Users Say Thank You to Skip Fix For This Useful Post: | ||
My heads flow a tad better than 225.
Dougs makes a 2" round port as well
i dont know if they make it any larger, as i thought there was another size as well i have the 1 7/8 and they are nice, especially for bolt access and everything else |
The Hookers also clear the ignition key/trans locking rods!
I have a set of the Doug's 2" headers that fit on my 1981 Firebird with a 421 motor.
Joe |
How’s the fit? Pics?Do they hang low like the hookers? They look identical to hookers 4202!
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
They actually fit pretty good. I did not have to make any modifications. I don't have any pics. The motor and car are sold. They didn't seem to hang low to me. I have not seen how low the Hookers are so I really can't compare them.
These are hooker 4202, they hang below my canton pan
I don't remember them being that low, but I can't say for sure. I sold the motor a couple of years ago.
