Old 08-28-2024, 08:43 PM
70KGOLD's Avatar
70KGOLD 70KGOLD is offline
Default 1975 Trans Am headers
Does anyone make a 2" roundport headers for a 1975 Trans Am? Dougs offer a set from 70 to 74. Only a 7/8 for 75 up.
Old 08-28-2024, 08:50 PM
I wouldn't know why they wouldn't work in 75 and up?
If wanting pipes all the way back to rear it may be hard to do.
But if open headers, should work?
Old 08-28-2024, 09:57 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Hooker does, they advertise them as 70-74 due to the round port heads. I think the PN. is 4202
Go fast, see Elvis!
Old 08-28-2024, 10:48 PM
As Paul said Hooker 4202. Fit my 78 and the 79 Camaro with the IA motor in it. And IA block needs a little massaging esp on #1 to clear the block and freeze plug area.. May need a dimple near the rear lower A arm bracket on the frame. Some sets near the oil filter. one set i had was real bad at the oil filter.
ID:	639102   Click image for larger version
Old 08-29-2024, 05:37 AM
Why do you need 2" headers ?
To make good use of such and produce the highest average torque numbers your Exh ports would have to flow 225 cfm@ 28".
Old 08-29-2024, 10:22 AM
78w72 78w72 is offline
As mentioned hooker super comp #4202 fit 70-81 Firebirds, they are listed as 70-74 due to the O-port shape but fit all 70-81 with O-port heads.
I have them on a 72 Firebird with an E-head 400 block stroker, fit great overall with no problems getting a full size pontiac oil filter in/out.... only complaint is that they do hang down lower than most other headers due to the big tubes & collectors.
Old 08-29-2024, 03:47 PM
R 70 Judge's Avatar
I wish mine looked that nice!
I have Hooker 4202’s on my 70 TA with Flowmaster 4-2-1 collectors. They seem to work well and they give the car a very unique sound. I don’t think Flowmaster makes them any longer. The set on my car are 2” primary. I have a NOS set of Flownaster 4-2-1 in 2 1/8” that I bought new years in my garage. I planned on using them for a previous build and never got around to it.
James
1970 Trans Am
Old 08-29-2024, 07:09 PM
http://www.wallaceracing.com/header_length.php
A tid bit. Some calculators, formulas and performance recommendations use the tube's INSIDE diameter. If that's the case you would need to subtract twice the tube's wall thickness from the outer diameter.
If so that header material might be 16 gauge (.062") or 18 gauge (.049").
One example here: https://www.discountmags.com/magazin...is-issue/12912
Old information here:
Old 08-30-2024, 09:56 AM
I had GP headers copy a set of the Hookers in SS!
Old 08-30-2024, 05:47 PM
http://forums.maxperformanceinc.com/...ght=GP+headers
Mine
The Following 2 Users Say Thank You to Skip Fix For This Useful Post:
Old 08-31-2024, 03:29 PM
R 70 Judge's Avatar
Originally Posted by Skip Fix View Post
Wow! Those are super nice!
James
1970 Trans Am
Old 09-19-2024, 05:51 PM
70KGOLD's Avatar
My heads flow a tad better than 225.
Old 09-23-2024, 12:46 PM
Don 79 TA Don 79 TA is offline
Dougs makes a 2" round port as well
i dont know if they make it any larger, as i thought there was another size as well
i have the 1 7/8 and they are nice, especially for bolt access and everything else
Old 09-23-2024, 12:52 PM
The Hookers also clear the ignition key/trans locking rods!
Old 09-23-2024, 02:04 PM
421 Bird's Avatar
421 Bird 421 Bird is offline
I have a set of the Doug's 2" headers that fit on my 1981 Firebird with a 421 motor.
Joe
Old 06-10-2025, 10:34 PM
grandville455's Avatar
Joe
How’s the fit? Pics?Do they hang low like the hookers? They look identical to hookers 4202!
Darby
M/T 275/60 ET SS Drag Radial
Old 06-11-2025, 12:09 PM
421 Bird's Avatar
They actually fit pretty good. I did not have to make any modifications. I don't have any pics. The motor and car are sold. They didn't seem to hang low to me. I have not seen how low the Hookers are so I really can't compare them.
Old 06-11-2025, 07:04 PM
These are hooker 4202, they hang below my canton pan
Darby
Old 06-12-2025, 12:10 PM
421 Bird's Avatar
I don't remember them being that low, but I can't say for sure. I sold the motor a couple of years ago.
