Old 09-02-2024, 06:03 PM
napster's Avatar
napster napster is offline
Default 1973 Trans Am updates
New Paint Job, Total Rewire of car, bigger cooling fans that you can hear go on when I go to the front of the car. Both fans are Rallye 16" and pull 4,000 cfm. New overflow reservoir for radiator was installed along with Autometer gauges for oil pressure and water temperature. The gauges were installed in the spot where the 8 track tape player would go. Dynamat was installed for sound purposes. Last item was a Ridetech bolt in 4-link installed to run coil overs and BMR anti-sway bar was installed upfront. A Ridetech rear sway bar was installed as part of the 4-link kit. Also, major work was done on the rear exhaust so the tailpipes would look stock placement.
https://youtu.be/7ejfm83NhdE
The Following 3 Users Say Thank You to napster For This Useful Post:
Old 09-02-2024, 06:10 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Nice!
Go fast, see Elvis!
Old 09-02-2024, 06:26 PM
grivera's Avatar
grivera grivera is offline
F’n love that car!! Fantastic job - sounds and looks awesome. Thanks for posting link.
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
67Lemons 67Lemons is offline
Sweet!
The Following User Says Thank You to 67Lemons For This Useful Post:
Old 09-02-2024, 06:36 PM
jhein's Avatar
jhein jhein is offline
Ver nice!
The Following User Says Thank You to jhein For This Useful Post:
Old 09-02-2024, 06:40 PM
napster's Avatar
Here are some pictures from the video.
ID:	639359   Click image for larger version
ID:	639360   Click image for larger version
ID:	639361   Click image for larger version
ID:	639362   Click image for larger version
The Following 2 Users Say Thank You to napster For This Useful Post:
Old 09-02-2024, 06:53 PM
jhein's Avatar
Looks great! What size tires are those?
Old 09-02-2024, 07:35 PM
napster's Avatar
Thanks! 255/60/R15 all the way around.
Old 09-02-2024, 10:49 PM
BLUE TA's Avatar
BLUE TA BLUE TA is offline
Thumbs up
l love your car and the color. BLUE TA
The Following User Says Thank You to BLUE TA For This Useful Post:
Old 09-02-2024, 11:27 PM
Verdoro 68's Avatar
Man, that thing sounds tough!
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 09-03-2024, 09:28 AM
napster's Avatar
Only other item that might be changed is the steering box. With the change to the back it makes the front seem loose now. If I'm not mistaken the '73 steering box is 3 full turns lock to lock and the WS6 is 2.5 turns and should bring back the quick response. Only have to see if the WS6 steering box will clear the new fans.
Old 09-03-2024, 11:55 AM
kingbuzzo kingbuzzo is online now
Just wow....
I just did the borgensen and it is nite & day better than my stock unit...but I guess you can't stray too far from stock with that beauty!
Old 09-03-2024, 04:20 PM
napster's Avatar
Just wow....
Kingbuzzo,
Thanks for the comment. However, not realizing what you said confirms what I have been trying to do with this car and that is to keep it looking as cosmetically stock as possible with a lot going on underneath.
Here is a link that will show you what I'm talking about:
https://forums.maxperformanceinc.com...d.php?t=839167
Old 09-03-2024, 05:09 PM
amazing upgrades...
Old 09-04-2024, 10:26 AM
Jim Moshier's Avatar
Sweet looking ride! Now its time to enjoy it. How long was it in Paint jail?
Jim Moshier
1962 Catalina 389
The Following User Says Thank You to Jim Moshier For This Useful Post:
Old 09-05-2024, 09:54 AM
napster's Avatar
Thanks. Roughly three months.
