New Paint Job, Total Rewire of car, bigger cooling fans that you can hear go on when I go to the front of the car. Both fans are Rallye 16" and pull 4,000 cfm. New overflow reservoir for radiator was installed along with Autometer gauges for oil pressure and water temperature. The gauges were installed in the spot where the 8 track tape player would go. Dynamat was installed for sound purposes. Last item was a Ridetech bolt in 4-link installed to run coil overs and BMR anti-sway bar was installed upfront. A Ridetech rear sway bar was installed as part of the 4-link kit. Also, major work was done on the rear exhaust so the tailpipes would look stock placement.
https://youtu.be/7ejfm83NhdE Last edited by napster; 09-02-2024 at 06:41 PM. |
| The Following 3 Users Say Thank You to napster For This Useful Post: | ||
Nice!
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
F’n love that car!! Fantastic job - sounds and looks awesome. Thanks for posting link.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
| The Following User Says Thank You to grivera For This Useful Post: | ||
Sweet!
| The Following User Says Thank You to 67Lemons For This Useful Post: | ||
Ver nice!
| The Following User Says Thank You to jhein For This Useful Post: | ||
Here are some pictures from the video.
Looks great! What size tires are those?
Thanks! 255/60/R15 all the way around.
l love your car and the color. BLUE TA
| The Following User Says Thank You to BLUE TA For This Useful Post: | ||
Man, that thing sounds tough!
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
| The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
Only other item that might be changed is the steering box. With the change to the back it makes the front seem loose now. If I'm not mistaken the '73 steering box is 3 full turns lock to lock and the WS6 is 2.5 turns and should bring back the quick response. Only have to see if the WS6 steering box will clear the new fans.
Just wow....
I just did the borgensen and it is nite & day better than my stock unit...but I guess you can't stray too far from stock with that beauty!
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
| The Following User Says Thank You to kingbuzzo For This Useful Post: | ||
Thanks for the comment. However, not realizing what you said confirms what I have been trying to do with this car and that is to keep it looking as cosmetically stock as possible with a lot going on underneath. Here is a link that will show you what I'm talking about: https://forums.maxperformanceinc.com...d.php?t=839167 |
amazing upgrades...
Sweet looking ride! Now its time to enjoy it. How long was it in Paint jail?
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
| The Following User Says Thank You to Jim Moshier For This Useful Post: | ||
Thanks. Roughly three months.
