Old 04-16-2025, 03:38 PM
TheCeleryStalker TheCeleryStalker is offline
Default 69 "button" style shifter in a 68?
I like the look of the 69 faux walnut shift knob with the firebird button. I currently have the stock T-Handle style shifter. Will the 69 knob work for me as a simple bolt on?
Old 04-17-2025, 08:34 AM
I should add I have a 68 with the th350
Old 04-17-2025, 10:16 AM
Keith Seymore's Avatar
You talking manual trans?
As long as the threads are the same it should bolt right on.
Even if they are not you can redrill/retap or helicoil to make them all the same.
https://67-72chevytrucks.com/vboard/...t=knob&page=12
K
'63 LeMans Convertible
'63 Grand Prix
Old 04-17-2025, 10:17 AM
K
No this is the T Handle automatic shifter. Id like to replace it with the "knob" style shifter with the button on top.
This is what I have currently: https://www.firebirdcentral.com/1968.../tra-2056k.htm
I am wondering if its a simple bolt on to convert it to this: https://www.firebirdcentral.com/1969.../tra-2056u.htm
The Following User Says Thank You to TheCeleryStalker For This Useful Post:
Old 04-17-2025, 11:25 AM
grandam1979 grandam1979 is online now
No it will not work the handle is different you need a shifter from a gto (a body) to work I did it to my car. I actually took a 69 shifter for the ratchet and added the neutral safety switch part from an older shifter to work in the 68 bird but one from a 68 will bolt right in with just the bracket on rear of shifter changed.
Old 04-17-2025, 11:26 AM
Thanks for the info!
Old 04-17-2025, 05:19 PM
The stick needs this groove for the clip so the ball doesn’t fall to the bottom of the stick. I think it’s just a little longer also. I checked the stick in neutral for length.
ID:	650439   Click image for larger version
