Old 05-26-2025, 01:44 PM
oldman66gto's Avatar
oldman66gto oldman66gto is offline
Default Coolant Additive- Purple Ice
Has anyone used the Purple Ice coolant additive product? It is supposed to help reduce coolant temps 10-12 degrees. It has decent reviews, but !'m not familiar with it.
I would be adding to a 50/50 coolant mixture.
As you can guess, I'm having a bit of a cooling temp issue, and here in Florida the 85-90 degree days don't make it any easier, especially with a/c running.
Currently has a 180 degree T-stat
Thanks,
Allan
PS: Read about "Water Wetter", a similar product, but comments were that it could cause radiator sludge, something I do not want!
Old 05-26-2025, 06:37 PM
ID67goat's Avatar
ID67goat ID67goat is offline
Have used water wetter in the past and did not experience any sludge and it improved the cooling around 7-8 degrees.
The Following User Says Thank You to ID67goat For This Useful Post:
Old 05-27-2025, 10:32 AM
I saw the comment in reviews, and you know how they can be.
But was curious about actual usage.
Old 05-27-2025, 11:12 AM
srmmmm's Avatar
srmmmm srmmmm is offline
Same here. Worked well in multiple vehicles for me.
Old 05-27-2025, 11:51 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
I use Rislone super coolant since it's the only coolant additive that actually matches the color of the conventional green coolant, so it doesn't discolor it - finicky, but I'm OCD.
All of those additives work by the same principle in that they make the coolant more "soapy" and hydrophilic, so that it more readily sticks to the metal surfaces and transfer the heat more effectively.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
The Following User Says Thank You to nUcLeArEnVoY For This Useful Post:
Old 05-27-2025, 06:37 PM
Thanks, I like your response that it is the same color! May buy some tomorrow, at "Wally World"!
