Old 04-26-2025, 11:24 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
Default Wheel well height
Can someone tell me what the measurement is from the ground to the wheel opening lip with the chrome trim going straight up though the wheel center? I know stock tire height is 26.2"s but my tire height is 27.1 inch.
I am still using the original coil springs and I think they may have sagged a little as I have a tire rub at times right at the top of the wheel opening. I remove the fender to fender liner top bolt and that help for a little while , but now the rub is back.
It is more pronounced on the passenger side and gets worse when there is someone sitting on that side. On rare occasions I get a little scrub on the drivers side.
Old 04-27-2025, 04:03 AM
Kenth's Avatar
Kenth Kenth is offline
Time for new springs?
Name:	66-67 rocker panel height.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 04-29-2025, 10:14 PM
fyrffytr1's Avatar
Thanks, I will measure the height Thursday.
Old 05-15-2025, 09:32 PM
fyrffytr1's Avatar
Sorry for not replying sooner. Life got in the way and I haven't measured the height yet. I am in no big hurry now because temps are reaching the mid 90s so I won't be taking the car out anytime in the near future.
Old 06-08-2025, 10:47 PM
fyrffytr1's Avatar
I got around to measuring the height a couple days ago and then this site went down. Anyway, with a full tank and tires inflated the passenger side was 8.75 inches and the drivers side was 8.5.I am running aftermarket wheels and tires but they are the same diameter as the stock combo. Looks like new springs may be needed. What brand do you recommend?
Old 06-09-2025, 04:02 AM
gto4ben gto4ben is offline
These are the heights of my car. The front springs were from Eaton Detroit Spring MC3474 and the rear were Moog 5409.
ID:	652650   Click image for larger version
ID:	652651   Click image for larger version
ID:	652652   Click image for larger version
Name:	Roof Height.jpg
ID:	652654   Click image for larger version
The Following 2 Users Say Thank You to gto4ben For This Useful Post:
Old 06-09-2025, 09:16 PM
fyrffytr1's Avatar
I can't find the Moog 5409s anywhere on line or locally.
Old 06-09-2025, 11:34 PM
Try to find an equivalent to the Moog specs. Eaton Detroit Spring will have it as an alternative and you can bring the rear higher by request.
Name:	Moog 5409 specifications.jpg
ID:	652707   Click image for larger version
Name:	1967 GTO 2 Dr Convertible 1.jpg
Old 06-10-2025, 05:47 AM
Kenth's Avatar
N/A?
https://www.rockauto.com/en/moreinfo...choice=0-0-1-1
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 06-10-2025, 08:56 AM
Gator67's Avatar
Gator67 Gator67 is offline
I have a new set of +1" Eaton Detroit springs listed in the for sale section if you're interested.
Old 06-11-2025, 10:27 PM
fyrffytr1's Avatar
I may be interested in them later on, if they are still available, but right now I think I need to focus on the fronts. They are the ones giving me the most trouble.
Old 06-23-2025, 08:24 PM
grivera's Avatar
grivera grivera is offline
Interesting that the station wagons without heavy duty springs are higher at the rocker than the ones with.
Will Rivera
Old 06-23-2025, 11:45 PM
fyrffytr1's Avatar
I thought I remembered reading that there was a spring for cars with A/C?
Old 06-24-2025, 10:59 AM
Yes, the factory had a different set of front springs to carry the additional AC weight. In '67, the code was LN. It had a spring rate of 305 lbs./in.
Name:	Compare OEM to Eaton 1.jpg
ID:	653357   Click image for larger version
ID:	653358   Click image for larger version
Name:	LN AC Front Springs.jpg
The Following User Says Thank You to gto4ben For This Useful Post:
