Old 07-24-2025, 07:39 PM
svspeed69 svspeed69 is offline
Default 1970 Judge hood bump?
There was a white 1970 Judge for sale at Norwalk. A friend of mine was talking to the seller who was telling him that 1970 Judges had some sort of a bump in the hood to accommodate the Ram Air 5 engine. I've never heard of such a thing, my friend said the seller was quite knowledgeable about GTO Judges and owned a shop that built and restored cars. The Ram Air 5 was not a production engine, and I have no idea why they would put a bump in the hood of a 1970 Judge to accommodate it. Anyone here ever heard of such a thing?
Old 07-24-2025, 08:09 PM
I've heard a lot of drinking goes on at Norwalk sometimes .
Could have been intended as a prank.
Old 07-24-2025, 08:17 PM
While the RAV was a unique engine there was nothing about it that would require any kind of hood modification.
Pure nonsense.
Old 07-24-2025, 08:23 PM
BOB VIDAN BOB VIDAN is offline
More beer!!!!!!!!!!!!!!!!!
Practicing social distancing for 65+ years
The Following 2 Users Say Thank You to BOB VIDAN For This Useful Post:
Old 07-24-2025, 09:13 PM
I hope you had your hip waders on... that BS is really deep..
Old 07-24-2025, 09:50 PM
importsmasher's Avatar
importsmasher importsmasher is offline
Not the hood, obviously, but I seem to remember reading somewhere many (like 40) years ago that the lower Ram Air pan was shaped to clear the Holley carburetor that was intended to be used on the RA V. Don't know if that's true, but maybe that's what he was thinking of?
Importsmasher
Scott Baggiore
66 GTO convertible 389/4 speed (parents bought new)
73 Firebird Formula 400/4 speed
74 GTO 455/4 speed
74 Grand Am
Old 07-24-2025, 10:35 PM
Naw, the story deal was the OHC-6 SPRINT needed the hood bump to clear the cam tower.
Old 07-24-2025, 10:41 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
Importsmasher
Same…I’m not aware of any difference in 68-70 hoods, “bump” wise. I believe the air cleaner base deal was referenced in one of Pete’s books or Zazarine’s, with an accompanying photo.
costs too much
Old 07-25-2025, 10:18 AM
Dont the 70 air cleaner bases have bumps to clear Holley 4 barrel float bowl adjusters? Think I read that somewhere. That would have been a RA V only carb.
Old 07-25-2025, 02:53 PM
72projectbird's Avatar
The guy clearly bumped his head. Maybe that's what he was trying to say?
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 07-29-2025, 07:52 PM
steve25 steve25 is online now
Yes, the late 69 and 70 air cleaner bases made for the RA motors had push up in them so as to clear the float adjuster set screw and lock nut on the Holley carbs the RA5 motors came with.
There was not one difference in the hoods other then I heard once that had the RA5 gone into production for the masses the hood tack would have been part of the package and not optional as on the RAIII.
Old 07-30-2025, 03:14 AM
Kenth's Avatar
Kenth Kenth is offline
Only the 1970 air cleaner bases made for the RA motors had push up in them so as to clear the float adjuster set screw and lock nut on the Holley carbs the RAV motors came with.
In 1969 they do not have these bumps.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 07-30-2025, 05:14 AM
Well thats not fully true Kenth because I have seen a late Aug RA4 who’s air cleaner base had them.
So while I might not be 100% right, neither are you.
Old 07-30-2025, 03:22 PM
Kenth's Avatar
1970 production started 8-11-1969.
For 1969 RAIV cars they did not have these bumps on the carb pan, at least not from factory.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 07-30-2025, 03:52 PM
Just like when 4 bolt main fitted blocks have been used as service replacement blocks in warranted 2 bbl motors this took place dispite what all of your catalogs say that you have.
Believe what you want, but I know what I saw on a non restored 2 year old car way back then.
Old 07-31-2025, 11:41 PM
wase's Avatar
wase wase is offline
The resto shop owner may have been thinking of the differences of the 1968 to 1970 hoods, where after '68 the inner brace structure was bumped up in the front area to clear the 1969 & 1970 fan shroud design.
The Following User Says Thank You to wase For This Useful Post:
Old 08-04-2025, 05:54 PM
henley henley is offline
70 models had the hood clearanced in preparation for the required smog pump. Most engines also had the two front intake bolts installed on the right side with studs for the same reason. Gov never made GM put the pumps on after all. Look most pics of the V engines and they wore a smog pump
63 Z-11 JACKSHAW CHEVROLET CAR
67 PLUM SAFARI WAGON
68 ROAD RUNNER HEMI 4- SPEED
69 RA V JUDGE
70 RA III 4- SPEED CONV. GTO
73 FIREBIRD
98 MUSTANG CONV
05 LEXUS SC430 CONV
08 LEXUS ES350
15 SILVERADO
Old 08-05-2025, 05:57 AM
Scott Thelander's Avatar
Default 70 RAM AIR hood
Heres my spare 70 RAM AIR hood
68 has neither
69 has the bump at the top
70 has the compressed area that is the lower flat spot
Im pointing to
Scott
ID:	655232   Click image for larger version
The Following User Says Thank You to Scott Thelander For This Useful Post:
Old 08-05-2025, 04:19 PM
orejudge orejudge is offline
Henley, Maybe the people that commented bs might learn something but I doubt it. Thanks for the picture Scott, yes three different underbracing on the 68 69 70 hoods.
Old 08-05-2025, 04:40 PM
A bump in the hood.
A stamped recess in the inner structure.
Same thing? Not really.
Great to see 2 of our long-time members with a little over 400 posts between them in roughly 20 years sharing their knowledge on the forums and helping others to keep the Pontiac hobby alive.
