Old 07-21-2025, 11:12 AM
provocating provocating is offline
Default Picture of wire going into temp sending unit
Can anyone that has a fairly original trans-am around a 1979 post a picture of the wire going into the temp sending unit, I need to see the routing and the color of the wire.
Old 07-28-2025, 12:05 PM
Hot Pontiac Hot Pontiac is offline
Default Temprature is rising What to do ?
Have '63 Grand Prix What to do for temp Rising above 180 degrees.Question:What do you have to do to keep that 389 Running at 180 all day long,With out converting to Small block chevy Water pump, the combination Timing Chain Cover and Water Pump Properties are not a good Desighn.
Old 07-28-2025, 12:50 PM
I am not understand. This post is about wanting a picture of a sending unit on a 79 trans am. I do not even have a 389
1979 Trans Am - 454 - Turbo Hydromatic 400
Old 07-28-2025, 04:26 PM
What the heck is post #2 about here, besides it not relating to post # 1 at all?
Old 07-28-2025, 04:32 PM
I am trying to recall what my 79 had.
The wire I know came out of the Alternator harness, the wire I want to say was dark green, but not sure.
Old 08-12-2025, 11:47 AM
autobahn autobahn is offline
I am really interested on how your going "convert to a chevy water pump
JIM
Old 08-13-2025, 10:45 AM
burd burd is offline
Green wire, routes through a black plastic tie in valve cover, loops around out front, rite into the Con loom.
White connector on the wire
