| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Found a 64 Grand Prix a couple hundred miles away, so I haven't looked at it yet, but I thought that I would get the opinion of the herd on its value before I drove 3 hours to look at it.
The seller says that it is a 421 4bbl, auto trans, with the gauge package and will "drive under its own power with a gallon jug of gas." ![]() ![]() ![]() ![]() ![]()
No! Do not try! Do! Or do not. There is no try. - Yoda 1967 Firebird Restoration 2005 - 1/25/2017
$800.
Only if it actually does have a 421. That thing is a rotted mess. I wouldn’t bother making the drive to look at it until the seller confirms it’s a 421, the engine code and the presence of a transfer lug on the block will tell you.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
I have seen alot worse, but I agree that it is probably only worth the value of the engine at this point. The other parts are a hard sell, Pontiac B bodies are just not that valuable unless they are one of the performance versions. A good solid runner doesn't usually top $20k in sales unless it is a manual transmission, or tripower or a SD or 2+2.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
So what's a "running" 421 going for nowadays?
Does it have a title?????????
DBANDGB |
The 4-barrel 1964 421 came with the low-performance small valve 345 heads, dime a dozen and nobody’s looking for them or will pay anything for them.
All of the Tri-Power 421 engines that year used the sought after big valve 716 heads. Doubtful this engine has those heads (GTO 389s all used them too) but you never know, chances are slim to none. The only items of real value are the block and crank. Likely the timing cover is rotten and no longer useable. So as a runner who knows exactly maybe a grand or so after you’ve done the work extracting it from that wreck. The knowledgeable buyer isn’t going to run it in their car as is nor will they want to pay a lot for parts attached to it they don’t want.
Good parts car.
Bucket seats have value... as well as some other odds and ends.. depending on condition.. $1,000-$1,500 car
Current Pontiacs -1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
If you want to go to the trouble of parting it out it is worth more as a parts car. I disagree that no one wants a 421 4bbl. that is in running condition. That is exactly what I have in my 1964 GP. The car has many good parts. Maybe in Florida nobody will want it. In this part of the country (NE) it would be worth more than in the south or west. But, you have to want to part it out.
I would think $ 2200 -2500 tops,
That's an I want it price, not an " I think there's money to be made on it price" I think a 421 that you can bolt a starter to is worth 1500, At least that's what it would take to get my short block out from under my bench. The rest is probably worth $1000. The odds of it being a 421 are probably slim. JMHO, Good luck |
