Old 09-13-2025, 01:02 PM
besserspat besserspat is offline
Default Holley Street Dominator versions
I have a Holley SD going on one of my engines because my 71 HO intake barely made it out of Dave's SD performance shop fire a few years ago when getting a full port job.
I picked up two more Holley SDs yesterday from a very nice gentleman, I thought is would be interesting to post pics here since they are the two different versions I know of the SD.
My memory is blurry but wasnt one made to line up with the shaker hood or something? The carb pad position seems a little off and one is obviously.more open ( less casting) .
Can someone shed aome light on this . Just curious.
Peter
ID:	657055   Click image for larger version
ID:	657056   Click image for larger version
ID:	657057   Click image for larger version
ID:	657058   Click image for larger version
The Following 2 Users Say Thank You to besserspat For This Useful Post:
Old 09-13-2025, 02:04 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Nice! The one that's not cut out around the EGR boss is the first design. I always thought they changed the casting a bit to save on material. I never noticed any other differences. The first design definitely weighs a good amount more than the second.
Go fast, see Elvis!
The Following 3 Users Say Thank You to PAUL K For This Useful Post:
Old 09-13-2025, 02:27 PM
form74's Avatar
form74 form74 is online now
Looks like the one I got 2nd generation one got it with the last 400 motor I bought
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
The Following User Says Thank You to form74 For This Useful Post:
Old 09-13-2025, 05:00 PM
Held for Ransom's Avatar
There are three versions that I know of. I'll look after the show to see if I have pictures of them.
So long, farewell.
Old 09-13-2025, 08:26 PM
PAUL K's Avatar
I perfer the later version like yours
Go fast, see Elvis!
Old 09-13-2025, 09:55 PM
First one has more aluminum and
FIRING ORDER
18436572 in front.
Second one had
FIRING
ORDER
18436572 in back.
Third one had
FIRE ORDER
18436572 in back.
ID:	657110   Click image for larger version
ID:	657112   Click image for larger version
So long, farewell.
Old 09-14-2025, 10:12 AM
Those manifolds are crying for a bead blasting to look pretty again
I'll have to go in the attic and look at mine. Never been on an engine, got it form Speedway years ago!
They also have the W casting mark from Winters foundry like most of the factory GM aluminum manifolds.
Old 09-14-2025, 11:10 AM
FIRING ORDER
18436572 in front.
Second one had
FIRING
ORDER
18436572 in back.
Third one had
FIRE ORDER
18436572 in back.
Isn"t the second and third the same?
Old 09-14-2025, 06:17 PM
FIRING ORDER VS FIRE ORDER
Old 09-15-2025, 02:12 AM
Pontiac Performance Author
Edelbrock Buick Performer Carb pad is set. about 1" to the rear vs B4B.
Old 09-15-2025, 09:21 AM
form74's Avatar
FIRING ORDER
18436572 in front.
Second one had
FIRING
ORDER
18436572 in back.
Third one had
FIRE ORDER
18436572 in back.
Got the third version
74 Formula
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Performer RPM
