Old 09-15-2025, 12:10 PM
Shiny Shiny is offline
This is great info, thank you again!
So there weren't 521 "lines"...
Were these line numbers unique for each plant? Brands could share the same lines, right? So would their build sheets also show the same line number or would, for example, 521 reflect a Pontiac built on line 21 and a Chevy might be an 0421 on the same line ??
Old 09-15-2025, 12:42 PM
One thing could be an employee ID of some sort, or the general dept or something to that effect.
In most of my factory jobs one would have to sign off with ID of something, or the dept had to sign off, etc on jobs.
Or a job would have a ID number of some sort, like Keith's build sequence or something. Also a date/time number.
Like said, if more samples it would make it easier to see the associations.
Old 09-15-2025, 03:27 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
Default Info from PHS only, plus the window sticker
Name:	68 gto.JPG.jpg
Name:	68 gto P2.JPG.jpg
color me gone
Old 09-15-2025, 06:19 PM
Here's a few pics of the 'Line No.' on a partial build sheet for a 1968 GTO.
I'm not sure how they populate the number, but possibly something like Fremont did? (HFR may know more)
But I'm leaning to the '153' as the Line No. from build sheet. The other 4 digits could be for the cowl tag body #, or at least what they think it might be at time of input in computer?
I don't have many 68 build sheets (at least readable) or no interior tags.
Possibly someone with a 68 fetish may know more.
ID:	657229   Click image for larger version
ID:	657230   Click image for larger version
Old 09-15-2025, 07:28 PM
Keith Seymore's Avatar
Yes - they count up independently of any other plant.
Multiple nameplates can go down the same line. Fremont had Buick, Olds and Pontiac. Flint had GMC and Chevy (sometimes on the same truck). When I started at Hamtramck it was Buick Lucerne, Cadillac (including limo) and Volt.
Each nameplate would have its own VIN sequence counting up independent of the other. The general assembly number would count up one for one regardless of anything else.
K
'63 LeMans Convertible
'63 Grand Prix
The Following User Says Thank You to Keith Seymore For This Useful Post:
Old 09-16-2025, 11:49 AM
1969GTO's Avatar
Great information all....thank you
color me gone
The Following User Says Thank You to 1969GTO For This Useful Post:
Old 09-26-2025, 07:03 PM
1969GTO's Avatar
Default What's this
Originally Posted by 1969GTO View Post
the only reason I pulled the rear seats was because for some reason owners like to just leave the seat belts on the floor after having some work done in that area, the package tray is new and the seats had to be removed to do the job correctly.
The seat belts have now been washed, dried and back in the proper position.
ID:	657782 I removed the original engine from my 68 GTO and found this bracket, any reason for this or is it a factory item?
color me gone
Old 09-30-2025, 11:22 PM
Factory item for heat riser valve.
Old 10-01-2025, 12:59 PM
1969GTO's Avatar
Default Part
see post #26
color me gone
