Old 09-13-2025, 10:15 PM
Norwood's Avatar
Norwood Norwood is offline
Ive used cylax in the past and in my opinion Por 15 brush on manifold paint is a better product
The Following User Says Thank You to Norwood For This Useful Post:
  #402
Old 09-14-2025, 08:05 AM
Starting to work on the window trim. I hit them with a few rounds of oven cleaner to strip the old anodized coating off them, straightened any damage, and wet sanded the pieces starting at 400 grit and worked up to 2000 grit.
Afterwards I hit them with some white and red polishing rouge on a bench top grinder that I put polishing wheels on.
First pic shows a piece stripped and wet sanded next to two pieces that haven't been touched. Second and third pic show a wet sanded piece against a polished piece. They're not the easiest things to take pictures of.
Wow! Those look fantastic!
Would love it if someone came out with stainless ones, not sure why no one has done that yet, makes total sense to me. Those things would fly off the shelves. The aluminum ones can't take even the slightest rock-shot.
  #403
Old 09-14-2025, 09:01 AM
72projectbird's Avatar
I've used their manifold paint on a few cars, and I like it.
Thanks! I got very lucky with these ones, as they were virtually undamaged. Very little straightening had to be done.
The reproduction stuff is great that it's available at all, but it's definitely flimsy, and fitment isn't the greatest.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #404
Old 09-14-2025, 10:40 AM
ramairhart ramairhart is offline
Wow, those interior parts look fantastic. Did y’all use dye or plastic paint? What brand?
Thanks, Alan
“A veteran - wether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to the (‘United States of America’, for an amount of ‘ up to and including their life.’” Unknown
  #405
Old 09-14-2025, 11:00 AM
Thanks, Alan
It's a custom mix, color matched to the Legendary door panels and seat covers. It looks spot on.
I'm super happy with how they came out
1987 Grand National
  #406
Old 09-15-2025, 05:51 PM
Any of you guys have experience getting reproduction sail panels to fit? The ones I have are from The Parts Place, and they are really fighting me. The most noticeable and worst part is where it fits around the rear window. They are a good 1/2" from sitting where they should, making them look like ass when looking thru the back window.
1987 Grand National
  #407
Old 09-15-2025, 07:03 PM
srmmmm's Avatar
srmmmm srmmmm is offline
I would suggest light application with a heat gun to gently reshape, but I'm not sure how that might affect your pain finish on them.
  #408
Old 09-15-2025, 07:16 PM
That's what I'm planning on. Wish I fit them before they were painted, but oh well. I checked them against my crumbling, disgusting originals and they just fall right into place.
Gotta love reproduction parts, huh?
1987 Grand National
  #409
Old 09-15-2025, 07:51 PM
Norwood's Avatar
Just a note so you don’t buy another set from someone else. Most of these parts have one repop that they all sell. Get them to fit as best you can and keep looking for som originals. JMHO.
  #410
Old 09-16-2025, 09:02 AM
Dang. I haven't tried fitting mine, now I'm curious how long ago I got them...
  #411
Old 09-16-2025, 11:42 AM
srmmmm's Avatar
I'm having trouble with paint not sticking to interior panels. Upholstery shop has tried three times and finally said the plastic used for the panels will not accept any etching step to improve paint adhesion. Fortunately, the rub off only shows where the door pad is contacting the kick panel edge and rear quarter trim edge so it's only visible when you open the door. I guess I can live with it as opposed to replacing all the trim panels again. You can only take apart the interior so many times.
  #412
Old 09-16-2025, 01:05 PM
Here's the awful gap after having the panel in and out no less than 10 times. Looks like ass.
I'm pulling it out again, and painting the visible white sheet metal with some black paint to try and disguise the fact that these panels suck. I guess I'm on the hunt for good originals.
1987 Grand National
  #413
Old 09-16-2025, 05:34 PM
unruhjonny's Avatar
Just an idea;
Had you considered using something akin to butyl tape to hold the top of the panel in place?
Maybe even some heavy duty two sided tape?
Unless I am misinterpreting that image, it looks like the shape of the (inner) sail panel is wrong...
1970 Formula 400
  #414
Old 09-17-2025, 11:42 AM
Originally Posted by unruhjonny View Post
Just an idea;
The shape is definitely not correct. I'll try shaping them with a heat gun, and possibly stuff some butyl tape behind them.
Here's another pic of the lovely fitment you get for your money
1987 Grand National
  #415
Old 09-17-2025, 11:59 AM
Do you remember which supplier it is, were they in OER boxes?
Maybe my run is better since it was a considerable time ago, but think I will get out there and test fit them. Dang.
  #416
Old 09-17-2025, 12:44 PM
They're from these guys:
https://www.thepartsplaceinc.com/pro...ductions/21358
Apparently they're "show quality" lol
I'll continue to fight with them and see how they turn out.
Along with the rear window fitment sucking, the part of the panels that go under the steel headliner trim above the door glass is too wide to fit under the trim. I was able to cut some of the plastic out to allow the steel trim to overlap it correctly, but man these panels certainly make you work for everything.
1987 Grand National
  #417
Old 09-17-2025, 12:48 PM
unruhjonny's Avatar
I hope you're able to make them work.
These panels were virtually unobtainable for many years - making decent ones which were not dry rotted few and far between.
I have 2-1/2 sets in various condition (one set is from/for my car);
As I recall from collecting them, the 1974 panels were a one-year piece, I believe it had to do with the coat hook.
1970 Formula 400
  #418
Old 09-17-2025, 04:08 PM
It's funny, I couldn't remember if this car had coat hooks so I ordered them. Turns out it doesn't have em lol
I have a set in my 71 that I believe are original as they fit great. I think I might pull them out of that car and put them in the 70.
1987 Grand National
  #419
Old 09-17-2025, 05:14 PM
unruhjonny's Avatar
The coat hooks for the early cars had the coat hooks up on the headliner;
(again if my memory serves me) They moved to the sail panel for 1974
ID:	657335   Click image for larger version
Name:	012 coat hook on sail panel.jpg
1970 Formula 400
  #420
Old 09-17-2025, 05:19 PM
Formulabruce's Avatar
IIRC the 70 std interior = No coat hooks..
" Long may we DRIVE !"
