Old 01-11-2026, 07:02 PM
Gary H's Avatar
Gary H Gary H is offline
Default Race header sizing
I'm getting ready to have another set of headers fabricated for my car and I wanted to get some knowledgeable opinions on header size. My current headers are stepped 2 1/16" to 2.25" primaries. The combination is in my signature below, but the engine is 541 CI, and I shift around 7800 rpm. HP is around 1050. Does anyone else have a similar combination, and what size headers are you running?
Old 01-12-2026, 12:04 PM
triathlonx13's Avatar
Tagging on - Always good to hear opinions and possibilities of facts.
Old 01-13-2026, 12:21 PM
Gary H's Avatar
OK, I spoke with Jeff at KRE and he recommended starting with a 2 1/8" primary for around 12-15", then stepped to 2.25", then to a 3.5" merge collector. Any thoughts on this?
Old 01-13-2026, 01:11 PM
srmmmm's Avatar
srmmmm srmmmm is offline
This is a Trans Am series car. 358 cu in engine, 935HP @ 8600rpm. 2.25 inch pipes into 2.5 inch pipes into 3 inch Y-pipes into 4 inch side pipes.
We swapped out the engine in just over two hours after it had lost coolant pressure in the last 15 minutes of a practice run. Big increase in crankcase pressure the next time out indicated rings were toast. It was only a $60,000 muck up.
Then pinion bearing gave out during qualifying and we had to swap out the carrier the night before the race. Hypoid gear lube is an excellent skin softener.
ID:	663593   Click image for larger version
ID:	663594   Click image for larger version
ID:	663595   Click image for larger version
Old 01-13-2026, 02:29 PM
I'd try Larry Meaux' Pipe Max and see what it says?
Just a rough estimate I'd think it would need a little more?
(need a lot of engine specs to use it)
Old 01-13-2026, 02:47 PM
John Langer's Avatar
John Langer John Langer is offline
2-1/8 for around 4” to 2-1/4 to 2-3/8 total length under 28” into a 4” merge collector. Clocked for firing order
The Following 4 Users Say Thank You to John Langer For This Useful Post:
Old 01-13-2026, 05:37 PM
Steve C. Steve C. is offline
A FWIW, John's combo in my signature uses 2 1/4- 2 3/8 step header, 34 primary length, 4.5 collector.
526 CID
4.500 / 4.315 / 6.7
HP heads / 13.2 :1
Victor intake w/Cloverleaf spacer & sheer plate
8896 Dominator carb
920hp at 7000 rpm
Old information here:
Old 01-13-2026, 07:28 PM
Gary H's Avatar
Exactly what I was looking for. Thanks!!
The Following User Says Thank You to Gary H For This Useful Post:
Old 01-14-2026, 11:52 AM
PAUL K's Avatar
PAUL K PAUL K is offline
That's what I'd do
Go fast, see Elvis!
Old 01-14-2026, 10:21 PM
aaronman aaronman is offline
Here are my SS headers. Very close to what John suggested. I run 2.125-2.25" and merge collectors clocked to firing order at 900 to 950hp depending on combination in car.
The Following 2 Users Say Thank You to aaronman For This Useful Post:
Old 01-16-2026, 06:05 PM
blueghoast's Avatar
WOW Nice and great fitment too
GT
Old 01-26-2026, 09:13 AM
BDHABT's Avatar
BDHABT BDHABT is offline
We tried 2 different sets of headers on the dyno.
2"-2 1/8" 947HP
2 1/8"-2 1/4"-2 3/8"-2 1/2" 963HP
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
The Following 3 Users Say Thank You to BDHABT For This Useful Post:
Old 01-26-2026, 10:32 PM
blueghoast's Avatar
2"-2 1/8" 947HP
Thats a pretty good jump, wouldn't of exspected that much from a step
header.
GT
