Old 01-26-2026, 09:18 PM
Joog Joog is offline
Default Dual or single carb intake?
I am building a stroker 462 with aluminum heads for a gasser I am building for street strip use. I was wondering what intakes you guys use? Should I go with a dual carb or single carb setup? What works better?
Old 01-26-2026, 10:27 PM
blueghoast's Avatar
I've run a victor with a 1050 dom and a wensler with two 4150 carbs
Both seam to be about the same in my world. Others might chime in
and give there results too. The two-four motor was a 440 and the
dominater motor was a 462. I gota say the two 4 motor is impressive.
GT
Old 01-27-2026, 02:11 PM
GT
Was this on the same engine, just different intakes? Or was this two separate engines? If so, what was the differences between them beside intake and carbs
Old 01-27-2026, 03:46 PM
misterp266's Avatar
Gasser? Run a bathtub intake, it’ll look awesome!
" Darksiders Rule "
The Following User Says Thank You to misterp266 For This Useful Post:
Old 01-27-2026, 04:41 PM
OFFYL Dual QUAL (dual Spreadbore for me) seemed quite responsive. And the low height with center-divider design is not shabby.
Way lighter and lower than a Wenzler Dual Quad.
Old 01-27-2026, 04:51 PM
There was a recent run of Bathtub intakes that even take late model heads!
Gasser has to have dual quads at least. Maybe a Warrior TR.
Name:	Bathtub  Holleyswq.jpg
Old 01-27-2026, 05:01 PM
Great to see that. Lotta intakes I see don’t fit late model heads.
Old 01-27-2026, 05:02 PM
I’m not scared to cut the hood
The Following 2 Users Say Thank You to Joog For This Useful Post:
Old 01-28-2026, 03:36 PM
misterp266's Avatar
What is this going in? Post up a pic of your car!
" Darksiders Rule "
Old 01-28-2026, 04:24 PM
56 star chief custom Catalina. Previous owner was planning on doing a quick flip on it and put a 350 Chevy in it, yuck! So I got it and have not had the time or room to take the front end sheet metal off to start getting the straight axle under it. Going to do a front plate mounted 400/462 from the 400 coming out of our 67 GP this coming weekend.
ID:	664316   Click image for larger version
ID:	664318   Click image for larger version
Old 01-28-2026, 04:56 PM
Can you fit an Hei with an offenhauser? Does an Hei fit with any of these dual quads?
Old 01-28-2026, 05:52 PM
tom s tom s is offline
Large cap HEIs wont fit most dual quads and tripower intakes.Tom
Old 01-28-2026, 09:11 PM
I have a stock Pontiac HEI and I was considering a DUI. Guessing the DUI won’t fit? Is it enough of a clearance issue where you can’t just notch out the intake a little?
Old 01-28-2026, 10:27 PM
Stock size pontiac dizzy works fine.Tom
Old 01-29-2026, 12:34 AM
blueghoast's Avatar
Two complete different motors.
462 11:5:1 eddy heads solid roller victor and 1050 dominator.
(428) 440 eddy heads wenzler TR two 750 carbs 10:65:1 Allum rods
Both motors make close to 650 hp and are pump gas motors, see a lot
of street driving and drag-n-drive fun.
GT
Old 01-30-2026, 10:08 AM
mgarblik mgarblik is offline
Your car will be cool when ready to run! Looks great. Stock HEI is going to be a big PIA to run with any 2X4 intake on a Pontiac IMO. I would recommend running a stock Pontiac Points dist. or an old transistor ignition dist. to trigger an MSD box. Or a small bowl aftermarket distributor. Several brands available. If you can swing it, the Bathtub intake would look absolutely awesome in that car! I have run the old warrior intakes, the Wensler Gutsram, and the Offy 2X4 intakes. They can all be tuned to work fine in a gasser style car. A bathtub wins the best of show award. An Offy 5149 would be the least expensive by far. Good luck with it.
Old 01-31-2026, 02:34 PM
I want to think I have an HEI in the motor I have my Warrior TR on
Old 02-01-2026, 01:16 AM
Id like to run an HEI if I can, I'll have to look around and see what I can do.
Old 02-07-2026, 01:46 AM
KGTO's Avatar
KGTO KGTO is offline
KRE's intake with 2 Pro Systems Holleys
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 02-18-2026, 11:55 AM
Should I do vacuum or mechanical secondary carbs? Street strip car but will drive It to shows when I can but would like to race it when I can too
