I am building a stroker 462 with aluminum heads for a gasser I am building for street strip use. I was wondering what intakes you guys use? Should I go with a dual carb or single carb setup? What works better?
Both seam to be about the same in my world. Others might chime in and give there results too. The two-four motor was a 440 and the dominater motor was a 462. I gota say the two 4 motor is impressive. GT |
Gasser? Run a bathtub intake, it’ll look awesome!
" Darksiders Rule "
| The Following User Says Thank You to misterp266 For This Useful Post: | ||
OFFYL Dual QUAL (dual Spreadbore for me) seemed quite responsive. And the low height with center-divider design is not shabby.
Way lighter and lower than a Wenzler Dual Quad. |
| The Following User Says Thank You to Half-Inch Stud For This Useful Post: | ||
There was a recent run of Bathtub intakes that even take late model heads!
Gasser has to have dual quads at least. Maybe a Warrior TR.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
| The Following User Says Thank You to Skip Fix For This Useful Post: | ||
Great to see that. Lotta intakes I see don’t fit late model heads.
| The Following 2 Users Say Thank You to Joog For This Useful Post: | ||
What is this going in? Post up a pic of your car!
" Darksiders Rule "
56 star chief custom Catalina. Previous owner was planning on doing a quick flip on it and put a 350 Chevy in it, yuck! So I got it and have not had the time or room to take the front end sheet metal off to start getting the straight axle under it. Going to do a front plate mounted 400/462 from the 400 coming out of our 67 GP this coming weekend.
Can you fit an Hei with an offenhauser? Does an Hei fit with any of these dual quads?
Large cap HEIs wont fit most dual quads and tripower intakes.Tom
| The Following User Says Thank You to tom s For This Useful Post: | ||
I have a stock Pontiac HEI and I was considering a DUI. Guessing the DUI won’t fit? Is it enough of a clearance issue where you can’t just notch out the intake a little?
Stock size pontiac dizzy works fine.Tom
462 11:5:1 eddy heads solid roller victor and 1050 dominator. (428) 440 eddy heads wenzler TR two 750 carbs 10:65:1 Allum rods Both motors make close to 650 hp and are pump gas motors, see a lot of street driving and drag-n-drive fun. GT |
Your car will be cool when ready to run! Looks great. Stock HEI is going to be a big PIA to run with any 2X4 intake on a Pontiac IMO. I would recommend running a stock Pontiac Points dist. or an old transistor ignition dist. to trigger an MSD box. Or a small bowl aftermarket distributor. Several brands available. If you can swing it, the Bathtub intake would look absolutely awesome in that car! I have run the old warrior intakes, the Wensler Gutsram, and the Offy 2X4 intakes. They can all be tuned to work fine in a gasser style car. A bathtub wins the best of show award. An Offy 5149 would be the least expensive by far. Good luck with it.
| The Following User Says Thank You to mgarblik For This Useful Post: | ||
I want to think I have an HEI in the motor I have my Warrior TR on
KRE's intake with 2 Pro Systems Holleys
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot 1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD! 1964 421 GP-Sold 6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold |
Should I do vacuum or mechanical secondary carbs? Street strip car but will drive It to shows when I can but would like to race it when I can too
