Old 03-28-2026, 06:50 PM
boardog boardog is offline
Default 1967 firebird info
Can someone decode this build? The car has the factory rear end torque bars that mount under the rear floor pans. It also is a ram air car.
ID:	667125   Click image for larger version
ID:	667126   Click image for larger version
Old 03-28-2026, 06:52 PM
Default 67 firebird
I can't get my pics to upload correctly
I have rotated them both ways with no luck. Sorry.
Old 03-29-2026, 03:45 PM
trishieldchief's Avatar
If it has 2 rear axle torque bars it is either a factory 326 HO or 400 Firebird.
If just a a single torque bar, just a 6 cylinder or 326 2bbl car.
Rich Johns
www.purestockauto.com
1970 GS 455 M21 4 Speed 3.42
1987 GN Astro Roof
Old 03-29-2026, 04:31 PM
johnta1 johnta1 is online now
It's a 326 HO engine in it originally.
Old 03-29-2026, 05:01 PM
einstein's Avatar
einstein einstein is offline
If I correctly recall, one arm versus two is tied only to axle ratio, and I believe it's spelled out in an image in the 1967 Firebird supplement service manual. Pretty sure the Sprint manual transmission got two bars. I don't have access to my library at this time, but it was probably 3.36 or 3.55 and higher numerically.
Old 03-29-2026, 05:03 PM
Manual trans got 2 rods except for 1bbl 6cyl which got one rod.
Old 03-29-2026, 05:05 PM
frankyboy455 frankyboy455 is offline
one arm: automatic, two arms: stick shift. I have a factory 67 Firebird 400 with a TH400 and it has one arm. Once had a regular 2bbl 326 with a factory 4 speed, and it had two arms. I think only the one barrel six cylinder had no arm, regardless if stick or auto.
The Following User Says Thank You to frankyboy455 For This Useful Post:
Old 03-29-2026, 08:53 PM
It is a 4 speed car.
Old 03-29-2026, 09:40 PM
Could you get ram air on the 326 ho? Even if the car was a late build was it a option? The car had been sitting for years. It had the complete ram air system on the car. I suppose it was owner added at some point.
Old 03-30-2026, 06:45 PM
muscle_collector's Avatar
no you could not
Old 05-17-2026, 11:37 PM
KentGBR KentGBR is offline
I also have a '67 Firebird HO w/manual trans. Compared to my car, yours is loaded with options. Here's a decode of your BHC using my PHS docs:
Regimental Red upper and lower
Black Std interior
Firebird HO
Pushbutton Radio, Front Manual Antenna
Rear Seat Speaker
Air Cleaner, Dual Stage H.D.
Pedal Trim Package
Deluxe Wheel Discs
Deluxe Steering Wheel
Electric Clock
Dual Exhausts
Dual Horns
Soft Ray Glass-Windshields Only
Spare Tire-Conventional
Front and Rear Floor Mats
Tachometer, Hood Mounted
E70 x 14, Red Stripe-Wide Oval
Safe-T-Track Rear Axle
4 Speed Manual-Floor Shift
