Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 06-12-2026, 01:19 PM
DA GOAT DA GOAT is offline
Default Wanted - 1972 intake, iron or aluminum HO
Got my 800 Qjet and now thinking about getting a 72 intake. Just not sure yet if I want to search for one that’s already ported or I port myself. Just kind of seeing what’s out there right now.
Old 06-12-2026, 03:40 PM
The stock intake is cheap and everywhere. I've got multiples. Where do you live?
The Following User Says Thank You to poncho-mike For This Useful Post:
Old 06-13-2026, 08:47 AM
I’m down in gulf shores, AL. I definitely would be looking at a stock iron or an aftermarket aluminum. Don’t need original aluminum as my motor isn’t original. Just going for more stock-ish appearing look
Old 06-13-2026, 11:15 AM
srmmmm's Avatar
srmmmm srmmmm is offline
Be cautious with a new aluminum repop. Before you spend the money for port matching, test the threaded holes for proper fit and perform a pressure test with dye penetrant if you can. I went through two RA-IV reproductions to get a good one. The first was a porous casting that had pinhole leaks in the front runners and crossover, the second suffered from temperature sender holes that were tapped too large in diameter.
Old 06-13-2026, 11:37 AM
That sounds painful. Are there certain companies/castings that are better than others?
Old 06-13-2026, 11:58 AM
65 Lamnas's Avatar
No, they’re all sh*t.
Just get an iron 1972 unit and put it on a diet.
The Following User Says Thank You to 65 Lamnas For This Useful Post:
Old 06-13-2026, 12:46 PM
73ta's Avatar
73ta 73ta is online now
Most all require port matching and welding to get the core shift fixed.
The Following User Says Thank You to 73ta For This Useful Post:
Old 06-13-2026, 04:36 PM
What do yall think of performer rpm?
Old 06-13-2026, 05:00 PM
73ta's Avatar
Good manifold if you can fit it under your hood. I have run one before.
Old 06-14-2026, 01:04 PM
PM sent. Thank you.
