Old 06-29-2026, 11:58 AM
chiphead's Avatar
chiphead chiphead is offline
Could it be leftover MFG tooling? Could it be from a mandrel or some factory fixture that was used to carry cranks around or to locate the completed engine during the MFG process? The tool and die shop just threw a random washer on the end of the MFG fixture, and it happens to stick in a crank some summer day in 1969?
Old 06-29-2026, 12:13 PM
Did they really have different cranks for automatic and manual transmissions? I thought all cranks were machined for a pilot bearing.
Old 07-01-2026, 01:41 PM
HO LEMANS's Avatar
HO LEMANS HO LEMANS is offline
Originally Posted by poncho447 View Post
That is the centering snout off of the torque converter.
you are 100% correct
NEVER DRINK DOWN STREAM FROM THE HERD
The Following User Says Thank You to HO LEMANS For This Useful Post:
Old 07-01-2026, 01:43 PM
HO LEMANS's Avatar
not all of them where finish machined, the steps are there just not sized for the bushing bearing whichever you prefer
Old 07-01-2026, 03:13 PM
That must be true of production parts only then as there is no difference between stick and automatic on the crankshaft part numbers for service parts.
Old 07-01-2026, 03:20 PM
HO LEMANS's Avatar
you could very well be correct on that I really don't know (I'm very sure there are some members of this forum that can tell us for sure though) I just know there is some discussion about this subject on this forum but honestly don't remember which thread it's in.
