Old 06-18-2026, 01:33 PM
Transamric's Avatar
Transamric Transamric is online now
Default Best Underhood Semi-gloss Black Paint??
I will be repainting my '71's inner fenders and radiator support soon. Haven't had to do this semi-gloss shade of black in several years now, and the products I used to use no longer exist. What have you guys found that is a good match for that underhood semi-gloss black?
Old 06-19-2026, 10:36 AM
78w72 78w72 is offline
If youre using a spray can... krylon satin is an excellent sheen & good quality paint, have used it on many parts under the hood etc, goes on smooth, dries fast & holds up to engine heat or debris from under the car.
Or if using spray gun, lots of options for brands, just ask for a color chart to show the sheen you want.
The Following 3 Users Say Thank You to 78w72 For This Useful Post:
Old 06-19-2026, 11:34 AM
OG68 OG68 is offline
X2 Krylon Satin
Old 06-20-2026, 07:37 AM
67Lemons 67Lemons is offline
X3 Krylon satin, I’ve also used Rustoleum satin and like that as well.
1972 GTO
Old 06-20-2026, 09:59 AM
Rustoleum is a good quality spray can or crush on paint.... only issue is that it takes a lot longer to dry, like 2 hours to the touch & overnight to 24hrs to be fully cured. And it is always on the glossier side, their semi gloss looks like other brands gloss.
But if cure time doesnt matter then its a good option, just do a test spot to see if you like the sheen.
Another option but more expensive is Eastwood paints, I tried some of their chassis black I think its called, good paint but for a fraction of the price and available locally, the Krylon satin black looks just as good IMO.
Old 07-08-2026, 10:30 AM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default DP90LF
Spray gun DP90LF is the best and very resistant to chemicals since it is 2K. Pefect color match in my opinion.
Spray can is Tuff Coat I think it's from O reilly's in Lacquer. Not very resilient but looks good.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
Old 07-08-2026, 11:20 AM
SRGN SRGN is offline
DP90LF is an epoxy primer, that's why it holds up. 2k just means it's 2 parts, base and hardener. I don't use that since they went LF(lead free) in the 90s. There's better options without the PPG price tag.
Old 07-08-2026, 12:34 PM
I prefer Duplicolor when it comes to rattle cans. It seems to lay down the best..
Old 07-09-2026, 09:50 AM
71HOT/A 71HOT/A is offline
DP90 would be my first choice. Very durable. Reduced 20-30% gives a nice semi gloss sheen. Yes it is expensive. One of the most, you get what you pay for products, I’ve ever used.
The Following User Says Thank You to 71HOT/A For This Useful Post:
Old 07-09-2026, 02:44 PM
skunkwerks's Avatar
Default Chalk
What better option brand are you thinking? I'm all ears for better and cheaper.
Please expound on this. Maybe I can try a new one that works.
They all seem to go chalky black over time Except for the PPG.
You get what you pay for.
All my high dollar resto's get PPG everything until I find something better.
LF works just as good as the leaded product. Still have both and use the leaded on certain items.
2K is an acronym for 2 part. I think we all know it's an epoxy primer.
Old 07-09-2026, 09:06 PM
Try southern polyurethane epoxy primer. Their stuff has replaced PPG in my garage, their clear coat is excellent as well. Does not get chalky after time like you have seen with others. I still use PPG base, I always liked Deltron for color match. The SPI stuff is great, all I need now is something that works as well as the old lead filled Imron for frames and I'll be set
Old 07-10-2026, 02:19 PM
Under hood black on 2nd Gens is NOT all the same gloss level.
Inner fenders & core support had a higher degree of gloss to them
than the face of the cowl, and for that matter DP90. So did numerous
supplemental parts like the '73, & '74-75 fender bars.
Old Today, 03:12 PM
Transamric's Avatar
Totally agree! Most of these black parts were enamel water dipped which is why on untouched original parts you will see dried drips, sags and runs.
Radiator supports were dipped, but not positive about inner skirts whether they were dipped or sprayed.
I love to pop a hood on a restored GM car and see different gloss levels on different items. "My kind 'O guy!"
Old Today, 03:22 PM
Transamric's Avatar
Used to use DP90 and liked the end results. Can't find it or L.F. anywhere anymore. For poof cans used Eastwoods Underhood Black. Very black and close semi-gloss finish. But mars SUPER easy. Even just doing normal dust removal cleaning leaves scratches. Krylon Satin Black (or Semi-Gloss) to my eyes is not very black. More charcoal looking and not enough gloss.
Have recently tried Rustoleum 2X Ultra-Cover Semi-gloss. Very black and decent semi gloss. But takes forever to cure. Small parts can be oven cured to speed up the process but big pieces are a pain to handle for almost 24 hours.
Thanks for all the input.
