Old 04-10-2014, 10:24 PM
mike leech's Avatar
mike leech mike leech is offline
thanks guys! and it was cool meeting you Aaron and thanks for the help
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 04-11-2014, 08:31 AM
estep455's Avatar
estep455 estep455 is offline
congrats mike!!! cant wait to see how it runs in the car.
Old 04-11-2014, 10:55 AM
Chris Petersen's Avatar
Chris Petersen Chris Petersen is offline
Send a message via MSN to Chris Petersen
Awesome #'s!
Are you going to put it in the car as is?
Converter change for the new power curve?
You had said you were going to try a few different carbs, was there one that was better than others?
Great job!
463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO!
Old 04-11-2014, 06:01 PM
mike leech's Avatar
Originally Posted by Chris Petersen View Post
Awesome #'s!
Great job!
Thank you!
yes it will go in the car with the same gear/convertor as last year. 6800convertor 4.10 gear. I'm sure it will want more gear and likely more convertor. Need to start somewhere and as it sits is a good start. Work from there so I don't go backwards and not know it. The convertor may react to the extra 50-60ftlbs of torque and fix itself.....I don't usually get that lucky though.
I tried one larger carb and it was 9 hp better than the one I currently have.
For R70 judge...no advantage on the paint. Looks cool though....
EHTTFMF!
Old 04-11-2014, 11:23 PM
Stan Weiss's Avatar
Originally Posted by mike leech View Post
Thank you!
Mike,
Thanks for the info.
Stan
Pontiac Pump Gas List
Old 04-11-2014, 11:30 PM
mike leech's Avatar
Originally Posted by Stan Weiss View Post
Mike,
Stan
You can ask for any info you like Stan. If something is sensitive I'll just say I'd rather not say. And you're welcome.
EHTTFMF!
Old 04-13-2014, 06:51 PM
cgeise's Avatar
cgeise cgeise is offline
Mike - have you tried the different wt trans fluids to change convertor stall yet ??? some say its worth 200 to 300 rpm.
Old 04-13-2014, 07:33 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
John Deere tractor hydrolic oil will tighten the converter up about 200 rpms, or at least it did on my junk. Just make sure you have about a quart of red transmission fluid so you can read the stick.
First Pontiac powered street car in the 7's
[email protected]. 3460#s
Old 04-13-2014, 07:44 PM
mike leech's Avatar
X2! I'll be going back to regular type f if its too tight. Got the JD hygaurd in their now.
EHTTFMF!
