Old 11-29-2011, 12:01 AM
blueghoast's Avatar
Well I ended up modifing a set of a-body pedals which was very easy to do.
I had to straighten the bends in them to get them over to the left side a
little more so I could move the gas pedel also. I just cut the sheet metal
that the gas pedal was mounted to and move the hole section over and
welded it back in place. The master cly. I took that and moved it up to the
next set of bolts above the original mounting place and opened up the hole
were it went inside the fire wall. Theres two holes in the brake pedal were
the linkage attatches the rod to the master cly. It's almost as if the factory
new I was going to do this modification and my cluch peadal linkage has a
bend in it so I can poke a hole in the fire wall just next to the sterring
colume and that will be inside of the inner fender well, I'm modifing a z-bar
so it will set in the stock location also. I can't believe how easy this is
comming together after I just stood back and thought about it a little bit.
GT.
  #202
Old 12-08-2011, 12:06 AM
blueghoast's Avatar
Originally Posted by c5farmer View Post
Finally back working on my project. Today, started installing the interior insulation for a cooler, quieter ride. The material is from a company called Fat Mat (fatmat.com). It is easy to cut with a carpet knife and install since it has self sticking backing. I think it goes for about $80 for 50 sq. ft. on ebay.
Next the wiring harness gets installed. For floor covering, I am thinking of using molded vinyl floor covering from Auto Interior and Upholstery. (www.auto-interior.com) They make a molded vinyl covering for '63 chevy II's that should fit a Tempest with a modified tranny tunnel. Anyone know of this company or purchased stuff from them?
c5farmer Did you ever order that vinal floor covering?
Just wondered how it looks and fits.
GT.
  #203
Old 12-09-2011, 02:11 PM
crossbreed455's Avatar
crossbreed455 crossbreed455 is offline
Making my 63 Tempest into a twin Turbo 474, (25.2 chassis ) just to have a little fun on the street. It will have 72mm too start with and be up grader to two 88mm when I get use to the car. Turbos are where the power is at. So I will have a lot of odd parts that will not be used.
  #204
Old 12-09-2011, 09:21 PM
blueghoast's Avatar
Cool:> Keep us posted.
  #205
Old 12-09-2011, 10:07 PM
Radman's Avatar
Radman Radman is offline
Default How far did you take your car?
I am still at the ugly part.
ID:	266485   Click image for larger version
ID:	266486   Click image for larger version
ID:	266487   Click image for larger version
ID:	266488   Click image for larger version
  #206
Old 12-10-2011, 12:12 AM
Doug Doug is offline
Thumbs up project stuff
Just finishing up on making upper shock mounts for my leaf spring rear end 63 Lemans.
Using 3"x3"x1/4" box tubing I made up bolt-on "brackets" that fit onto the subframe rails with flat plates inside the trunk to bolt to. Springs are on 46" center-to-center.
Basically, a small hole about 1 1/2" square is cut into the bottom of the frame rail to allow the top eye and bushing of the shock to fit up into. The bracket is "U" shaped to straddle the frame rail and it has a 1 1/2" hole cut for the shock eye and bushing to fit in. The bracket is drilled for mounting bolts including 4 holes in the top, 2 for the shock mounting bolts and 2 for tying the bracket to the bottom of the frame rail. When mounted the bracket fits solidly up against the bottom of the frame rail and the top of the bracket sits flush against the flange of the frame rail at the top. To reinforce the tying of the frame rail to the bracket, a piece of 1/4" flat stock about 1" wide and about 1 3/4" long (width of inside frame rail) is placed inside the frame rail on each side of the hole in the rail.
As shown in the pics, the sides of the frame rails are not perpendicular to the floor pan so the brackets had to be cut at an angle to fit the rails. The sides of the brackets are "contoured" to fit. Final assembly will use 5/16" bolts with locknuts for mounting to the trunk floor and bottom of rail and 3'8" bolts with locknuts for the shock mount.
Name:	bracket and plate.jpg
ID:	266497   Click image for larger version
Name:	bracket side view.jpg
ID:	266500   Click image for larger version
ID:	266501   Click image for larger version
Name:	mounted bracket outside.jpg
ID:	266502   Click image for larger version
Name:	mounted bracket inside view (639x640).jpg
  #207
Old 12-17-2011, 07:07 PM
blueghoast's Avatar
Just got back with the wagon.
To tired to mess with tonight.
Might take it down to the shop tomorrow.
GT.
  #208
Old 12-26-2011, 12:46 AM
R 70 Judge's Avatar
Nice! My next engine (after the one I'm currently building) will be a twin turbo deal with 76mm's. No 25.2 chassis for me though. I think my current set up should take me as fast as I want to go.
James
1970 Trans Am
  #209
Old 12-26-2011, 08:23 AM
spartazoo's Avatar
spartazoo spartazoo is offline
Redoing my top end to get into the 10.50's. New heads, intake, and cam.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
1966 GTO Hardtop - PS 14.84 @ 97mph
  #210
Old 12-28-2011, 07:53 PM
lreGTO65 lreGTO65 is offline
This is a great thread guys, lots of really nice looking stuff in here. I am hopefully going to pick up my '63 this weekend. I am thinking of converting it to a different form of "stock suspension". I might do a 25.3 chassis with a torque arm.
Right now this is just a though because I haven't actually laid underneath one of these cars yet.
Has anyone ever taken the front wheel wells out? Or is that not possible with the stock front suspension configuration? Anyone have any more pictures of the stock front suspension?
Is it a strut rod type like the old Impalas? Or is there still two lower control arm mounting locations?
  #211
Old 12-28-2011, 09:39 PM
mechanickeith's Avatar
A frame on top with a single arm with strut on bottom. The fenderwell is welded in & is part of the unit body strength.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #212
Old 12-28-2011, 09:56 PM
Strength wise, the chassis I will be building will be stronger than the stock piece is for sure.
  #213
Old 12-28-2011, 11:43 PM
Didnt now you were going to tube chassis it.
Keith Collier
Tech advisor
POCI.org
  #214
Old 12-29-2011, 11:21 AM
It won't be a full tube chassis, it will be like a 3/4 chassis type deal. But with putting the through the firewall bars in, along with a mid plate and motor plate the car will be solid up front. And on a drag radial car you would like to have a little forgiveness..
  #215
Old 12-29-2011, 08:28 PM
Anyone use the VFN bumpers and lower valances? Were they a PITA to mount? Any pictures?
  #216
Old 12-29-2011, 09:39 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
I used the VFN rear bumper and rear valance and they were a snap to install. I put the rear bumper on with Dzus fasteners so it can be removed easily. I put the valance on with machine screws and nuts. I don't have any close-up pictures (see sig for long shot).
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #217
Old 12-30-2011, 09:09 AM
Hooter's Avatar
Hooter Hooter is offline
My 496 is at Mondello's being redone into a 525. The old motor was a little loose and all is being redone - 4.5 Crower ultralight billet, BME rods, new pistons, lots of work on my wideports, LS1 cam, etc. Also sending in my glide to have the case recertified. I took it easy on the car last year trying to get used to it and not wanting to push the old motor. Looking to run easy 8's next year.....
67 Bonneville ragtop
  #218
Old 12-31-2011, 04:09 PM
R 70 Judge's Avatar
Maybe do a 25.5 deal then? At least you can keep most of the original floor.
ID:	268811   Click image for larger version
James
1970 Trans Am
  #219
Old 01-02-2012, 04:31 PM
It's going to be a 25.3, which is certfied to 6.50 under 3600lbs..
  #220
Old 01-23-2012, 12:10 PM
fasteddy's Avatar
fasteddy fasteddy is offline
Default my two
Guess I just like white.
fasteddy
