Closed Thread
Old 03-19-2019, 03:45 PM
dataway's Avatar
dataway dataway is offline
Originally Posted by torqhead View Post
Not that I have any say, but if I had a vote I would recommend sending it to Paul, he more than deserves an award for his unwavering support through this challenge!
Yep.
Old 05-03-2019, 11:46 AM
Va68goat's Avatar
Va68goat Va68goat is offline
STEELCITYFIREBIRD,
You make a good point because everyone here is a potential customer but at this point, I think I'll let Paul discuss that if he wants to. I'm in a pretty awkward position because I've spent a lot of money on a motor that has less than 200 miles on it and it's almost 2000 miles away from me.
Old 05-03-2019, 01:09 PM
promptcritical's Avatar
promptcritical promptcritical is offline
Originally Posted by Va68goat View Post
STEELCITYFIREBIRD,
Have you approached MSD? Their product seems to be the source of your problems, not the engine builder. He seems to be taking excellent care of you.
Old 05-05-2019, 07:33 PM
Va68goat's Avatar
promptcritical,
Hahaha..I'm not going down that path.
mgarblik,
This filter was suggested by a lot of guys here. That's why I went with it. I've tried googling problems with this distributor and didn't see much of the same problem. Of course I'm pretty new to cars and I certainly don't have the experience or knowledge to even have a thought on this. I know I'm learning a lot though!
Formulajones,
I don't know about the bypass. I know I've changed the oil 3 times with less than 200 miles.
Old 01-20-2019, 09:28 PM
tempest1964's Avatar
Keep at it. Perserverance will prevail. Good luck.
Old 02-06-2019, 08:46 PM
The oil pump should turn smooth, no bumps, hard spots or clicking. Was the oil pressure gauge steady, it may be dampened too much to pick up small fluctuations. Did it make noises when turning with the drill? If I remember the noise video, it was at half speed.
Bill Nye.
Old 02-28-2019, 10:41 AM
STEELCITYFIREBIRD's Avatar
Piston slap is usually most pronounced on a cold engine and then quiets down as expansion equalizes .
With that I assume it possible, like Paul said; collapsed in service. But when you fit the pistons, they are either in spec or not, and this builder is noticeably obsessive compulsive for detail!! (good for you!)
A good test would of been to kill a cylinder at a time and see if the noise goes away or lessens. Wrist pin and piston slap noise are most prominent on the power stoke.
Condition that could be a contributing/casual factor for collapsed skirt in service;
Running the engine high rpm or hard under load or unloaded/free rev it high/hard... COLD. Commonly done to show your buds what your hot rod sounds like.
These long stroke motors usually have comparably short skirts, don't know if that amplifies this condition, but I theorize it would.
Old 01-21-2019, 05:46 AM
Will Will is offline
RE: Ballooning torque converters.
Is it possible for a torque converter to expand/balloon while in operation but "shrink" back to normal when not rotating?
Old 01-21-2019, 10:48 AM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Default Just here for the results
I bought my cam based on GTOFREEK's recommendation, and I love it!!!! Keep at it, these things have happened to all of us. I adjusted my lifters 100'2 of times to find out it was an exhaust leak.
This is what happened to my friends Mustang last year from a failed lifter that was adjusted incorrectly..
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 02-21-2019, 07:26 PM
Va68goat's Avatar
Does anyone here remember the guy on the forum that makes and sells the Pontiac engine cradles?
Old 02-21-2019, 07:30 PM
Joe's Garage Joe's Garage is offline
Default This guy ??
http://forums.maxperformanceinc.com/...d.php?t=824217
Old 02-22-2019, 09:53 AM
craigs69's Avatar
craigs69 craigs69 is offline
Originally Posted by Joe's Garage View Post
Those are nice. I purchased one a few years ago.
Va68goat, if you have any trouble getting one, let me know and mine is available. I am in Wisconsin, so I would have to ship it to you. PM me if you are interested and we can work out the details.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds.
Old 02-28-2019, 10:42 AM
Do you plan to run it Paul, or dig right in??
Old 03-01-2019, 12:11 PM
gtofreek's Avatar
gtofreek gtofreek is offline
I'm tearing right into it. We have to pay to use a dyno to run it, and without mufflers, I'm not sure we'd even hear it on the dyno. Looking back at the dyno video's I made, you cannot hear any noise.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 02-22-2019, 01:55 PM
gtohunter's Avatar
gtohunter gtohunter is offline
My son had a Tbird Supercoupe and he dropped a replacement crate motor in it (supercharged V6). Around 20K on it, and it started knocking, so we pulled it. Found the thrust brg killed and upon looking, found the torque converter to have a very nice imprint of the flex plate bolts ! So, yeah, I'd have to say they do.
Jimmy M
68 GTO
Old 02-05-2019, 03:07 AM
dataway's Avatar
In my exhaustive study of the sound file extracted from the original movies you posted ... the sound was half engine speed ... but no one believed me.
Old 02-05-2019, 02:28 PM
dataway's Avatar
VA68 ... my last post was meant to be more humorous than serious. From my analysis it did appear the sound was half engine speed ... to me. But I certainly would not expect any competent engine builder or mechanic to take that as a fact. I was just trying to add some info to the mix.
I am however a true believer that a good sound tech, a couple of programmers and a half dozen good builders could develop software that could analyze an engines exact problem merely by the sounds the problem produces. An RPM sensor, couple of transducers on the engine and a database of known sound profiles.
But that is a discussion for another time.
Old 02-05-2019, 04:01 PM
tooski tooski is offline
I thought that when you found that the clicking occurred when you turned only the oil pump that no one suggested removing the oil pump and investigate that before shipping the whole engine back n forth. Of course easier done with engine pulled (but you would have to do that anyway to send it back).
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 02-22-2019, 02:10 PM
tom s tom s is offline
Guys,on the engine dolly,they are for sure the best.James is a one man show so sometimes the demand gets a little ahead of his production.Worth waiting for.Tom
Old 02-22-2019, 02:14 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
They are the best. I have 2 Pontiac and 2 Chevy ones. Best casters also.
Skip Fix
Closed Thread
