Closed Thread
Old 07-17-2015, 04:02 PM
GTOGEORGE's Avatar
Originally Posted by Motor Daddy View Post
When was it that people stopped talking crap about E-heads? If we get a date on that then we can know if it was less than or greater than 7 years?
Wait, people are still talking crap about E-heads.
All I gots to say is THANK YOU Larry Wenzler!
GTO George
Old 07-17-2015, 04:16 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
GTO George
BWAHAHAHAHAHAHA!
Please list the fast Wenzler Series II or Super Chief cars?
BTW, my dad has a set of Super Chiefs. He hasn't had any issues with them.
First Pontiac powered street car in the 7's
[email protected]. 3460#s
Old 07-17-2015, 04:28 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Originally Posted by LiL Jack View Post
BWAHAHAHAHAHAHA!
I believe Neal Owens and John Langer campaigned the Series II HPs back in the day and they did pretty well and not just against other Pontiacs in NMCA. As for now, obviously there are other and better choices.
Old 07-17-2015, 08:24 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
BWAHAHAHAHAHAHA!
My old Wenzler Super Chiefs have run both quicker and faster than any time you've ever posted.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 07-17-2015, 04:14 PM
LiL Jack's Avatar
LOL, usually it goes like this: "damn, he is that fast with E heads!"
Old 07-17-2015, 04:46 PM
PAUL K's Avatar
PAUL K PAUL K is online now
"Cylinder head envy"!
Go fast, see Elvis!
Old 07-17-2015, 05:44 PM
GTOGEORGE's Avatar
The so called e-head making all the power is a completely different head that Edelbrock casted.........wide ports, high ports, pushrods moved, offset rockers. the original head would not set ANY records! like I said before that you Larry Wenzler............ he was the FIRST!
GTO George
Old 07-17-2015, 07:36 PM
PAUL K's Avatar
GTO George
The Wenzler head as cast wouldn't set any records.
Go fast, see Elvis!
Old 07-17-2015, 04:44 PM
PAUL K's Avatar
Truth!
Go fast, see Elvis!
Old 07-17-2015, 05:17 PM
tom s tom s is offline
So did Ric Johnson.Tom
Old 07-17-2015, 05:19 PM
Both Ric and Dave ran in the 8s at 7lb per CI MANY years ago.Both were series one Ws.Tom
Old 07-17-2015, 05:45 PM
PAUL K's Avatar
Tom, not that it's a big deal but Dave had two pairs of Wenzlers, a series one and two. The series II's were the only ones to break into the eights. The series ones however have a better exhaust port but the series two were of better quality.
Go fast, see Elvis!
Old 07-17-2015, 05:51 PM
GTO Dan's Avatar
Back to the thread topic...how many of you think, regardless of the outcome of the race that most, at least those that posted in this thread, will not change their opinions.
Old 07-17-2015, 07:52 PM
Tom Vaught's Avatar
Boost Engineer
One weekend of data on two vehicles would not be a representative sample to make a change in "my opinion" of either head.
Jack "eats a hamburger" (arnie quote), one of the engines is wounded on the spray, etc,
too many variables.
Tom V.
Old 07-18-2015, 10:14 AM
You may be right on that point.
However, it would be interesting to see some NA passes on both combos. Seems a lot of non believers of Fulton's NA HP. No one with a Pontiac that I'm aware of has made 1100 plus HP NA at 13:1 compression. Little Jacks NA base power ???
Would be interesting to see how much power adder they added.
Possibly some opinions might change then.
Old 07-18-2015, 10:40 AM
GTOGEORGE's Avatar
You can't compare Power added engines without the power adder...........that would be silly. The engines are made for the PA addition. I would like to see at least 6-8 runs at Norwalk from BOTH these cars without any problems.........then I will be IMPRESSED!! I hope both cars run well and have NO problems.........we'll see.
GTO George
Old 07-19-2015, 07:12 AM
Tom Vaught's Avatar
Boost Engineer
GTO George
TRUTH!
That would be a good evaluation of the capabilities of both cars/drivers/race combinations on the same track, same week-end.
Tom V.
Old 07-18-2015, 11:57 AM
JSPONT's Avatar
JSPONT JSPONT is offline
I can't afford either head so my opinion won't matter.LOL
Old 07-18-2015, 01:34 PM
You can buy same ported casting as Fultons CV1 (max cast 330) with same valve job, same flow for far far less than a billet head + porting + valvetrain. It IS NOT a one off port. Bill digitized it over 3 years ago. Dick is not only one with this port, he finished his build sooner. Depending on how you intend to use it you might not need the shaft rockers or need as high a level valvetrain. Options obviously affect price. You can opt for lesser or greater port capability and other options as best fits your application.
And yes I get the budget thing. Its still going to be awhile before I can buy the entry level cv1's to replace my iron heads. With turbo's it just not a high priority.
Old 07-17-2015, 08:25 PM
Hooter's Avatar
Hooter Hooter is offline
I just hope someone brings a lot of beer to drink. Only requirement is must be over $2/6 pack quality.
67 Bonneville ragtop
Closed Thread
