Old 07-20-2017, 04:45 PM
TA455HO's Avatar
TA455HO TA455HO is offline
Calipers might be a bit too exacting for what you were asking but I got about
6 19/64" fractional
Would be fairly close to 6.25".
Chad
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
  #362
Old 07-20-2017, 06:29 PM
TA455HO's Avatar
From the very late 1970s or possibly 1980 - My buddy on the right in this photo just sent this to me the other day - his Mom probably took this picture before we headed out to a concert or something like that - Me on the left and his sister in the middle. That's my 1968 Firebird behind us. Ah the memories....not sure what I was cracking up about.
Chad
  #363
Old 07-20-2017, 06:43 PM
Judge273's Avatar
Judge273 Judge273 is offline
Cars and friends make great memories! Pictures like that are priceless!!
Mike/Illinois
  #364
Old 07-20-2017, 07:29 PM
Held for Ransom's Avatar
So it is the longer ones. Just trying to see if they repackaged the shorter ones as the longer ones at some point even though they were two different numbers.
  #365
Old 07-21-2017, 12:05 AM
TA455HO's Avatar
That's good to know. I wonder if the chrome shop I use will deal with the used door handles? I've removed the return spring on one, but other than that it doesn't seem like a lot more is easily disassembled.
Here's one of the horn button extensions, used for many years, of course. Just showing the listing for my car.
546280 2.820 All A, F & G EXTENSION, horn button (w/formula whl.) . 1 1971 1972 2-84
Chad
  #366
Old 07-21-2017, 05:48 AM
Bentwheelbob's Avatar
Your car should have the longer door handles so the NOS ones are correct.
  #367
Old 07-21-2017, 10:30 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Chad
Like Mike said - greats friends and cars make great memories. Love these old photos. Wish I had more of them!
BJ
Sent from my iPad using Tapatalk
  #368
Old 07-23-2017, 04:20 PM
TA455HO's Avatar
Here's another one of me next to the same 1968 Firebird in the high school parking lot about the same time frame.
Two things come to mind. I need a haircut and the Firebird needs a wash.
That's my friend Brett's car next to mine. A 1969....errr....Camaro.
This is before I got the torque thrust wheels and Radial T/As installed - the wheels came from the Camaro.
I think a girlfriend wanted a picture of me next to the car.
Chad
  #369
Old 07-24-2017, 01:32 PM
TA455HO's Avatar
A few more - I think I sold Bob one of these levers a while back - I hope that worked out OK.
9786981 2.897 All exc. X LEVER, dull black-exc. cruise control 1 1969 1972 2-86
Rear axle bearings.
7451405 5.855 All F .................... BEARING, roller (2 1/4" O.D.) 2 1970 1971 **5-31
3975648 4.785 All F GUIDE, rear cable 1 1970 1974 4-19
5464812 4.659 F/6-F/8-T/6-T/8-GP/8 Moraine P.B WASHER, vac. cyl. push rod limiter 1 1969 1972 **4-18
Chad
  #370
Old 07-24-2017, 02:29 PM
Judge273's Avatar
Isn't there only one ebrake tensioner needed?
Mike/Illinois
  #371
Old 07-24-2017, 02:50 PM
TA455HO's Avatar
Yes, just one per car - I think I have enough of many parts to build 4 cars total.
Chad
  #372
Old 07-24-2017, 05:49 PM
No, you weren't selling all the good stuff then, but I did get an NOS hazard knob and axle vent...
  #373
Old 07-24-2017, 06:09 PM
TA455HO's Avatar
Maybe I still have another lever around here, too. Trying to reduce excess but it is hard to keep track. At some point the mind does not seem to keep getting sharper.
Chad
  #374
Old 07-25-2017, 11:54 AM
unruhjonny's Avatar
Chad
wait.... what!?
1970 Formula 400
  #375
Old 07-25-2017, 05:33 PM
TA455HO's Avatar
Originally Posted by unruhjonny View Post
wait.... what!?
Exactly. That was funny!
  #376
Old 07-25-2017, 06:00 PM
Transamric's Avatar
Here's the one that came with my 1971 when I purchased it. Might have been replaced, I suppose. No ink stamped date on these like I notice on the speedometer backside.
Chad
Yes, the gauges with the higher temp numbers were Service Replacement parts for the earlier lower temp units.
To me, this is kind of like using the '73 dated talilamp lenses for a '70-72 car. They'll fit fine and work well, but not exactly identical.
Chad, I'd say you are correct in believing that the gauge assembly was changed before you got the TA.
  #377
Old 07-28-2017, 04:30 PM
TA455HO's Avatar
Thanks Ric. I'll get it squared away.
Here's a few more parts. This first one is a supercede
8877723 - the original number was
3906448 4.075 All A & F/455 H.O.-4 Spd. (4.010) PLUG, spark cont. switch hole, 4SP 1 1971 1971 **4-42
6437462 1.835 All V/8 exc. 307 ELEMENT (A.C.-type PF-24) 1 1964 1974 **1-39
5465205 4.924 F/6-F/8-T/6-T/8-GP/8 Moraine P.B BEARING, power piston 1 1967 1971 **4-20
Chad
  #378
Old 07-29-2017, 11:56 AM
TA455HO's Avatar
These drain plugs have the magnet built into them.
3968034 4.105 All 4 Spd. (Muncie)-- (4.103) PLUG, filler or drain, 4SP 2 1971 1975 ** 4-44
The purple one came with my car and I picked up a red one some years ago.
3987917 4.337 F GEAR, speedometer driven, 4SP 1 1970 1975 **4-51
17 teeth - purple
3987921 4.337 F F60 x 15 GEAR, speedometer driven, 4SP 1 1970 1975 **4-51
21 teeth - red
5467856 4.922 F/6-F/8-T/6-T/8-GP/8 Moraine P.B.-- (4.924) DIAPHRAGM, power piston 1 1969 1970 **4-19
5467788 4.913 All Moraine P.B.FILTER, vac. cyl. air (1/4'' I.D. x 1 1/2'' O.D.) 1 1964 1971 **4-19
Chad
  #379
Old 07-29-2017, 12:03 PM
77 Canamman's Avatar
Wink
I was under the impression that the PF-30 oil filter was installed at the factory during the '60's-'70's.
Also, I'm kinda curious how many have some reservations about running a 40-50 year old oil filter in their nicely rebuilt engine.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #380
Old 07-29-2017, 12:20 PM
TA455HO's Avatar
This is the list of applications in the Pontiac family that are in the lookup. Looks like the PF30 wasn't used until 1974 in the MPC. But, I did not remove the original oil filter from one of these cars ever.
6437462 1.835 All ELEMENT (A.C. type PF-24) 1 1960 1963 1-39
6437462 1.835 All V/8 exc. 307 ELEMENT (A.C.-type PF-24) 1 1964 1974 1-39
6437462 1.835 X/350 ELEMENT (A.C. type PF 24) 1 1975 1975 1-39
6437462 1.836 X (350) .................... FILTER, OIL (PF24) 1 1976 1976 1-60
6437462 1.836 ALL (350X) ................. FILTER, OIL (PF24) 1 1978 1980 1-60
6437994 1.835 All V/8 exc. X ELEMENT (A.C. type PF 30) 1 1975 1975 1-39
6437994 1.835 All X/260 ELEMENT (A.C. type PF30) 1 1975 1975 1-39
6437994 1.836 A, B, F, G (350, 400, 455) .... FILTER, OIL (PF30) 1 1976 1976 1-60
6437994 1.836 ALL (260) .................. FILTER, OIL (PF30) 1 1976 1977 1-60
6437994 1.836 ALL (350P, R, 400, 403) ...... FILTER, OIL (PF30) 1 1977 1977 1-60
6437994 1.836 ALL (400) .................. FILTER, OIL (PF30) 1 1978 1979 1-60
Chad
