Old 09-04-2006, 11:16 PM
Tom Vaught's Avatar
Boost Engineer
I posted a long time ago about the merits of the 67 block.
Maybe this post will clarify some of my thoughts in that area.
Tom V.
Old 09-05-2006, 05:04 AM
kookykrispy's Avatar
kookykrispy kookykrispy is offline
So is a 67 considered to be among the strongest 400's? I ask because I want to build a (relatively) bullet-proof shortblock (and I'd like to stay with a factory block) in the near future to support cranking up the boost on my 6-71 and possibly adding a bit of squeeze too.
"Keep your foot hard on that pedal
Son, never mind them brakes
Let it all hang out 'cause we got a run to make!"
Old 09-05-2006, 05:10 AM
screamingchief's Avatar
screamingchief screamingchief is offline
I went out and looked at all my blocks,all had thicker bulkheads than Skips block,most are early '70's (1-350,3-400's,1-455) blocks,one of them,a '70 YS 400 block was obviously thicker and cast differently from the later blocks,it looked more like the '67 block pictured by SergeF,but it still had some slight differences from that one too.
I tried to take pics but most turned out terrible,I'll take more tomorrow and post 'em,I'll try and get the year,and block casting #'s as well.
I'll dig thru my stored pics too,might have a pic of the bottom end of the 455 I dropped into my firebird not too long ago.
Gotta go,need sleep...
Old 09-05-2006, 07:25 AM
GRX's Avatar
GRX GRX is offline
Two blocks here, an early '67 "WT" - #9786133 ... and an early '75 "YJ" - #481988.
Comparring them side by side I noticed some VERY interesting differences, particularly in the parting lines. The two blocks look the same but the molds were structured quite differently. I'll post some images later today after another project is finished.
1969 GTO hard top ~ Std bore 400, '70-RA3 block, 670 heads, Bal. & Blue... M22, 12-bolt w/3:55s
Old 09-05-2006, 09:09 AM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
Here's a couple pics of the block from my race car. It's a 1969 block.
ID:	64291   Click image for larger version
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 09-05-2006, 10:39 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Looks like the material out to the dowels vs the bolts is the biggest thing showing up.
Old 09-05-2006, 03:05 PM
70 lucerne lemans's Avatar
70 lucerne lemans 70 lucerne lemans is offline
You guys have me nervous now! I just finished building my early 1975 400 block,I thought it had the thicker webbing,now Im not sure.Ill post the date code later if anyone could help.The motor is already done so I guess it would only be for peace of mind at this point.I did fill the block and stud the mains,looking for around 550-600 hp keeping it under 6000rpm.
Mark
1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD....
1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs
(1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor
[email protected] on 150 shot
Old 09-05-2006, 03:42 PM
My '70 YS block looks to be virtually identical to the pics of Jeff Walker's race block.
The bottom end on the '70 YS is still assembled,but that's the spittin' image of the casting it uses,his pic is better than what I'd get,really did'nt wanna break it down just for this deal,so that pic saves me some effort.
Only visible difference is the '70 block has the extra motor-mount bosses.
I'll be back with those pics a bit later.
Old 09-05-2006, 03:53 PM
Skip Fix's Avatar
My block(actually a brand new one) is a 76 casting made in 77, and the same casting my original 78 TA 180 hp had. I wanted opinions before I said what year it is. I'm glad we have some pictures to compare what areas are different.
Old 09-05-2006, 05:31 PM
I just looked at my date code again- I165 and casting # 500557.It looks like it was made in sept. 1975,I misread the code before.Dude could you chime in on this,I was planning on racing this one.
Mark
Old 09-05-2006, 05:59 PM
69birdboy 69birdboy is offline
500557 is not the thick one. I have one with the same casting number, and it's got good thick cylinders, but not thick under the caps!! I was planning on using mine to race too, but discovered I have to look for an earlier one.
69 firebird
Old 09-05-2006, 07:02 PM
PONTIAC DUDE's Avatar
Post
I really don't know about the date and run of the blocks.
I just go by looking at the webbing area. You will also notice that some blocks have the same meat under the cylinder and have a wider casting to meet the cap. In other words I have seen some blocks that are narrower then the cap and some that are the same width. Some that are wide then cut narrower right after the cap area on the block to the pan rail.
As far as how much abuse a certain thicker casting block will take over another. Your guess is as good as mine.
But bottom filling, deburring and studs to offset loads can't hurt.
Most I have encountered split right up the middle to the camshaft or from the dowels to the cam.
Old 09-05-2006, 07:45 PM
HWYSTR455's Avatar
I selected a block that a machine shop had and held for me for 3 years. I was ready to start on that engine, dropped the pistons & caps off, and when I went to pick it up it was a different block then I had originally picked. Mine's a 77 block, and the cap area is narrower then the thickness of the caps. I filled it to the bottom of the freeze plugs, studs & 4 bolt aftermarket caps, and I'm going ot throw it in my driver with a 3" stroker kit & e-heads. I'm going to spray it with a 150 shot and cross my fingers! Oh well, it's what I ended up with, and don't feel like throwing it in a corner. Think it will last if I don't put slicks on it?
Old 09-05-2006, 07:57 PM
flamedabone flamedabone is offline
You guys act like the thin block is a BAD thing...
Here is my '75 block from this spring. The motor was two years old...
The car is my daily driver mid/high 12 second 3000lb car. Fairly mild really..
-Abone.
Daily Driver Model A Ford. 389 Pontiac w/6-71. 10.80 @129.5
1933, 1934, 1936 and 1940 Fords, also Pontiac powered.
Old 09-05-2006, 08:56 PM
Good luck. I have split 2 of those kind of blocks. Not trying to be a smart a$$ but, Personally I don't know why the shop 4 bolted that block? Makes it even weaker in that area.
Old 09-05-2006, 11:41 PM
79bluebird's Avatar
79bluebird 79bluebird is offline
when did they stop makin the the thick version block? i have a late 72 400 that i makin a 416 stroker
Old 09-06-2006, 12:25 AM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
I have heard 1974...but I dont know. I do know that a '74 block (may be a '73) that I have appears to have more meat than the one Skip posted pics of.
  #38
Old 09-06-2006, 01:01 AM
Well,,,after some frustration with my digicam I'll post my pics.
First set is my race cars 400:
casting= 481988
date code= D093
Code= XN
application= '73 230 HP,A/T,4bbl.
Name:	400 race~1.JPG
ID:	64368   Click image for larger version
Name:	400 race 2~1.JPG
ID:	64369   Click image for larger version
Name:	400 race 5~1.JPG
ID:	64370   Click image for larger version
Name:	400 race valley~1.JPG
  #39
Old 09-06-2006, 01:07 AM
Next,spare 400 bare block w/caps:Valley is the same as race 400.
casting number= 481988
date code= l053
code= YH
application= '74 190 hp,A/T,2bbl.
Name:	400 block 2crop~1.JPG
ID:	64372   Click image for larger version
Name:	400 web~1.JPG
ID:	64373   Click image for larger version
Name:	400 web 2~1.JPG
  #40
Old 09-06-2006, 01:18 AM
And for now my spare 455 block,bare w/caps:
casting number= 485428
date code= ?183
code= YU
application= '74 250 hp,A/T,4bbl.
Name:	455 block 2 crop~1.JPG
ID:	64378   Click image for larger version
Name:	455 web4~1.JPG
ID:	64379   Click image for larger version
Name:	455 web~1small.JPG
