Old 09-05-2008, 07:20 PM
Deadhead's Avatar
Deadhead Deadhead is offline
Thumbs up
Originally Posted by mviker View Post
Y'all got me wondering about this DAG goo too, so I looked it up. We all know now! :P
"Dag 213 is designed to provide controlled electrical resistance properties. Dag 213 is a dispersion of finely divided graphite pigment in an epoxy resin solution. When properly cured, it has excellent adhesion to epoxy circuit boards, bushings, plastics and ceramics. Dag 213 also has excellent wearing properties. It provides chemical resistance to oils and many solvents, but not to enamel strippers.
Dag 213 as a lubricant coating provides clean, dry, long-wearing, and superior maintenance-free lubrication for a wide range of light to medium load applications. A thin film of Dag 213 keeps wear uniform and reduces friction on mating metal parts without requiring increased manufacturing tolerances. Components are protected from metal-to-metal contact even in applications approaching boundary lubrication, reducing the risk of damage due to partial or complete seizure. Formulated from processed micro-graphite and epoxy resin, Dag 213 forms tightly adherent coatings on many types of substrates. In addition to high lubricity, Dag 213 coatings exhibit extremely good wear resistance to oils and solvents (except enamel strippers)"
The rest is here:
http://64.233.169.104/search?q=cache...lnk&cd=1&gl=us
Very cool.
You gotta love this forum.
Matt, you need a 5 gallon bucket of this stuff. You know you want it.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 09-06-2008, 05:48 PM
65FATCAT's Avatar
65FATCAT 65FATCAT is offline
Default progress
Got a few pics from a collectors 66' auto 2+2, look at the linkage and tell me what you see, i don't know what's factory and what's custom, i just want something that works that doesn't look homemade, the other pics are at the shop, got the block off plates made and ready, the quarter panel pic is for arohed or anyone that needs it, looks nasty to me and has bondo slathered on there as well but someone might want it.
ID:	142202   Click image for larger version
ID:	142203   Click image for larger version
ID:	142204   Click image for larger version
Old 09-06-2008, 05:51 PM
65FATCAT's Avatar
Default shop pics
more
ID:	142206   Click image for larger version
ID:	142207   Click image for larger version
ID:	142208   Click image for larger version
Name:	passenger quarter.jpg
Old 09-06-2008, 06:05 PM
carbking's Avatar
carbking carbking is offline
Linkage in pictures definately NOT factory.
Jon.
Old 09-06-2008, 09:10 PM
mikediaz mikediaz is offline
http://k53.pbase.com/v3/09/553709/2/...4.L1000356.jpg
Here's a picture of what at first glance appears to me to be original linkage. it was a quick google image search for 1966 pontiac tri power. It's not too up close but int he future when you see setups, at least you'll have a better idea of what original more or less looked like.
I know AMES and Performance Years sells repro linkages, ebay usually sold a good little kit for about $100 with most of the pieces. Just mentioning some options!
Old 09-06-2008, 09:55 PM
Dick Boneske's Avatar
The linkage as pictured in the attached photo of a '66 Tripower I recently restored, consists of the slotted rod, center carb lever, rear carb throttle lever, and misc. studs & bolts, along with written instructions. I manufacture the linkage and sell it for $50. If you have any questions, PM me.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 09-07-2008, 12:57 AM
65FATCAT's Avatar
Ok Mike and Dick both of your pics appear to use the throttle cable, which would indicate a gto, the big cars i've seen all have the solid rod coming from that hinge thing on the firewall, does this make sense? maybe just the auto tri powers for all size cars have the solid rod, i don't know, and allmost every tri power picture has a different bracket for the return spring. I think i'm starting to develop a idea of what it needs to look like, but if someone had a linkage photo of a bone stock auto big car tri power that was in the car, it would help. Still waiting on parts, i guess i could have sprung for air delivery but i'm too cheap.
Old 09-07-2008, 02:14 AM
Carl A Carl A is offline
If these help here are pics I found of a 63 and 64 gp autos (I know I know not 65) but it gives you a idea for full size cars, pics show the top rod has a plunger system? to give the play before the end carbs open up, bottom rod goes to kick down linkage (picture you show only has two rods but you said it was a auto car?) as for the linkage on the 66 2+2 thats all custom stuff I have the same junk/stuff on a 64 tri set I have.
ID:	142279   Click image for larger version
Old 09-07-2008, 08:02 AM
Deadhead's Avatar
The factory auto Trips would have had a huge distillery of vacuum hoses, canisters & dashpots. I have yet to see one that is still on a car after 40 years.
My '66 GP has got a set-up with solid rods that snap together & are rigid. I believe it is a factory 4 speed linkage converted to use on an Automatic.
The Pics you have there look to me like that linkage would be subject to binding up. The angle of the linkage with respect to the plane of the outside of the 3 carbs is critical from my experience. The drooping on that rig is asking for trouble. I have to stomp the crap out of mine to engage it & that does not look like something I want to be stomping on.
ID:	142284   Click image for larger version
Name:	trip linkage.jpg
-LBJ
66 Bonneville wagon
2005 GMC L-33
Old 09-07-2008, 10:08 AM
65FATCAT,
The '66 big Pontiac linkage is identical to the GTO except for the stud that engages with the throttle rod from the firewall. The big car center lever has a ball stud that the throttle rod snaps into. The kit I described for the '66 big car Tripower has that ball stud instead of the straight one the GTO's use.
BONESTOCK GOATS
Old 09-07-2008, 12:36 PM
Engine-Ear's Avatar
Thumbs up regarding his repro parts..
Guys, I can vouch for the pieces he reproduces...they look great and work great.
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 09-07-2008, 10:15 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
Default i dont think the stuff turned up in google is the same stuff
Originally Posted by Engine-Ear View Post
"What is this dag 213 stuff?"
...I don't know either, but have you tried a Google search?
when i get a chance ill snap a few shots of my end carbs. the stuff mentioned in google sounds more like a lube where what iam talking about is a silicone type stuff but made to hold upto gas. it just brushes on around the edge of the blades and where they meet the bore. there use to be a guy name....i think carbdr on ebay that use to sell small tubes of it for about 20 bucks, its real hard to find
Old 09-09-2008, 01:01 PM
65FATCAT's Avatar
Car looks much better with the parts car chrome on it, it's in pretty sorry shape but looks decent from 20 feet, can't afford to have it redone right now.
Got the manifold on the parts car, still need distributor, vacuum line parts, linkage parts and various brackets to hold it all before trying to start it, i'll keep updating as i go along. Thanks to all for the info. provided.
ID:	142453   Click image for larger version
ID:	142454   Click image for larger version
ID:	142455   Click image for larger version
Name:	8-9-9 engine.jpg
Old 09-09-2008, 07:21 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Car looks good enough for me. '65 Convt with GP trim & taillights.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
Old 06-22-2009, 08:23 PM
Geeto-Tiger Geeto-Tiger is offline
as for my setup... i'm about $300-400 away from the rest of parts I need (sounds like a lot but it's just a few small things here and there that add up)... More importantly I have a 65 setup and a 64 engine so I my manifold won't work with it.. This really slowed down my install :-)
Mike,
Did you ever get it installed? If not yet (because of the heads), maybe I can assist you:
-I have a 64 intake you can use your carbs on
-I have 65 heads; #76
Gary
