Old 11-20-2009, 10:10 AM
Ollie's Avatar
Ollie Ollie is offline
Originally Posted by David Holmberg View Post
Out of the box KRE d-ports? I honestly don't think so.
However SD Performance sells several ported versions for not much more money, and they can and will support that and more.
2X. If you purchase the KRE heads from SD they will also recommend the cam.
Its ok to giggle and snicker, Dont laugh and point
Old 11-20-2009, 11:48 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
"The KRE heads in the 290cfm offerings will easily make more power at every rpm than the ported 62's." But Cliff I thought smaller iron heads were all we need and they beat those big aluminum ones
Skip Fix
Old 11-20-2009, 11:49 AM
TIN TIGR TIN TIGR is offline
who is this jim taylor fellow, and where did he come from?..is he old man taylors brother?
tune in tomorrow and find out..
on the next episode of.."as the cam turns"..
and now a word from our sponsor..
Old 11-20-2009, 12:06 PM
David Holmberg's Avatar
OMT lives on the west coast, and is of no relation to Jim Taylor on the east coast.
Old 11-20-2009, 12:09 PM
johnta1 johnta1 is online now
because he's a dushe
OMT, we all know you're not a 'dushe'.
We have a friend who's name is Jim Taylor also, who has a nickname of Pontiac Jack.
Maybe we should call you 'Pontiac Jack', but then Pontiac Jack would be po'd.
Any way, OMT is not the Jim Taylor in the poster's thread.
Old 11-20-2009, 12:12 PM
cant anyone see it was a joke..a joke, son, a joke..boy...sheesh..really?
Old 11-20-2009, 02:58 PM
As you can tell, it's a delicate subject.
Old 11-20-2009, 03:00 PM
PONTIAC DUDE's Avatar
Talking
That's why you need to add those smilies.
LOL
Bwahahahahahahahaha. Ah ha ha.
Laugh laugh, smirk, smirk.
Old 11-20-2009, 03:44 PM
I was referring to post #3, and OMT was also, I believe, not the 'joke' post?
Old 11-20-2009, 06:26 PM
rocky's Avatar
rocky rocky is offline
This post by no means pointed at OMT
Old 11-20-2009, 07:01 PM
goatracer goatracer is offline
Originally Posted by rocky View Post
I am running a ported 62 D port head thats been done by Jim Taylor. I have no idea what they flow cause he wont give up the flow numbers.I want to go to a set of KRE heads so I can run pump gas.The car right now runs 10.51 128.9 .The car is a 79 firebird 3600# w driver 455 1050 holley victor intake 630 lift cam 1.5 rockers 3800 ati conveter 4.10 gear. Question is can these heads out of the box flow enough to support the same mph and et that I have now
IMO, they're iron d-ports... how exotic can they be? Based on you're weight, engine size, mph... they'll be around 260ish +/-. If you want to spend the money and buy KRE's, add a couple more bucks and get'em ported. Why spend money and not go faster?
Bryan
Old 11-22-2009, 09:37 AM
Cliff R's Avatar
Cliff R Cliff R is offline
"But Cliff I thought smaller iron heads were all we need and they beat those big aluminum ones."
We've covered that ground many times. Nothing at all wrong with iron heads. Correctly ported samples have shown us they can and will make some pretty serious power, ET/MPH etc.
If you are paying for the work, the price quickly approaches buying aluminum heads in the first place, which is what I've done here since KRE came out with the aluminum "D" ports.
We haven't built a single 455 engine using them, that didn't make at least 500hp on pump fuel with relatively small cams, iron intakes, etc.
Even the 428 we built made 497hp at 5600rpm's, with unported KRE heads. I'm not going to spend countless hours with the grinder, or pay $1400 or more for ported iron heads, when I can get KRE's for a few hundred dollars more......FWIW.....Cliff
Old 11-22-2009, 02:03 PM
Scott M's Avatar
Scott M Scott M is offline
Exclamation
Well, he's in The Peoples Socialist Republic of New Jersey and rumor has it that he crawled out from under a rock.
Additionally, and not surprisingly, he is currently being sued over fraudulent misrepresentation in connecting with some shenanigans he pulled over on the folks who built The Righteous Judge.
I hope it bankrupts him.
Old 11-22-2009, 02:07 PM
Scott M's Avatar
Exclamation
Originally Posted by Cliff R View Post
I had contact with the Mr. Jim Taylor in question once, having to ask what cam was placed in one of his customers engines so I could set up his q-jet for it.
Never did get a straight answer, and was chastised for touching a carburetor that had just been completely/correctly rebuilt, and "dyno" tuned EXACTLY for the engine he had just completely rebuilt.
FWIW, it looked like it came from the bottom of a farm pond, then got Eastwood sprayed right over the grime, upper idle airbleeds smashed closed, primary shaft had about .030" side-play, excessively warped across the front/leaking at the gasket, WAY off on the jet and rods sizes, etc, no Viton parts, wrong power piston spring (clipped the stock one down some), etc, etc, etc.....but who am I to question what others are doing, I just wanted the darned cam specs so I could get the carb set up correctly?......Cliff
That sounds like the Jim Taylor from The Peoples Socialist Republic of New Jersey that everybody in the Philly area is familiar with.
Say, I wonder why he moved from the great bastion of conservatism, Pennsylvania, across the river, to the most liberal socialist State in the country?
To escape legal problems in PA?
Old 11-22-2009, 03:01 PM
Brian Baker's Avatar
Really? Where might I find this information? It should be public, no?
Old 11-22-2009, 03:33 PM
fastgto fastgto is offline
X 2
