Johnny Glad the new motor is working out well. Good luck at Pinks.
Conrad 79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Well darn, we got rained out tonight. That is the 2nd time this year for me but...what can you do. I really wanted to get some track time this weekend. My track doesn't have any racing this weekend but I can run it next Friday, Sat, and Sunday.
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected] 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1972 LeMans 350 Pontiac H/S Drags project |
We did some "wacking" on the car yesterday in order to get the bigger slicks to fit. I was running 28x9x15 Toyos, I now have a set of M/T stiff sidewall 29.5x10.5x15's stuffed in there.
Here's some before and after shots, think that will be enough room. I have 22psi in the slicks at the moment so they would be a bit fat for this. I'll start sanding today. We're going to run it hard this weekend, we have racing Fri night and all day Sat & Sun
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected] 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1972 LeMans 350 Pontiac H/S Drags project Last edited by Johnny406; 08-03-2010 at 02:02 PM. Reason: oops, wrong pic |
That was on speed tv tonight, I watched it, Very sad show if you ask me, I did not see a ponitac at all? All i saw was chevy-ford- dodge? I thought the guy in the chevy should have one it, NO they had to bring the dodge -to dodge out for the money? Sad show they puled that hit at bristol also.
They had a real winner
I got two runs in today, the 1st was a shakedown run and ran a easy 13.6. The second run I clocked a personal best 1.74 60 ft time and then proceeded to turn my driveshaft into a pretzel and break a u-joint. Must say, the motor is running strong...
That sucks.
72 GTO 400-M20 Lucy Blue 86 2+2 Black 09 G8 GT red 08 Torrent GXP (wife's) 09 G8 ST (UTE) black A pissed off fat house chimp on dope would be a lot more deadly. |
bummer
sounds like you have some power there
1980 TA 455 th400 2.56 posi [email protected] http://www.dragtimes.com/Pontiac-Tra...lip-29967.html http://www.youtube.com/watch?v=6X5XJ9PR1Qw https://www.youtube.com/user/hal101/videos Last edited by hal101; 08-07-2010 at 07:43 PM. |
No doubt I was on a personal best run when I broke it. That was a 1st for me, when it snapped it was LOUD, I thought I lost my new motor but it's fine, the rev limiter did its job. I can't believe how far I was able to coast the car as the shaft took out a brake line. I lost it around 1000 feet and still ran a 13.88 at 96.24 mph. Since there was no smoke and fluid, I rode it out to the first turn off (a swooping right) and coasted all the way to the turn off road. I didn't want to hit the e-brake and flat spot my slicks.
I'm real happy the rear joint snapped and the front of the shaft didn't try and join me in the car.
Glad to hear it was only a drive shaft even tho' that still blows. Keep hammerin'
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
A friend came over and we "studied" the driveshaft. It looks like the u-joint snapped and the damage to the shaft was from banging around and being dragged.
The u-joints were greasable heavy duty ones I bought and had pressed in about two years ago. I will go ahead and have a heavy duty shaft made up by Drive Line Specialties in Colorado Springs early in the week. I will either run solid 1310 series or go up to 1330-1350 series if I can rapidly find the yokes. I really wanted to get some "quality" track time prior to Pinks next week but...
Johnny you may want to check your pinion yoke and rear gears sometimes that shock of a broken driveshaft can affect trans. or rearends just be precautious and safe as well. Good lUCK
My quest for Pinks has ended, I just found that I busted the housing on my new two run transmission when I lost the driveshaft/u-joint.
The good news is the good folks at Bandimere are allowing me to award my spot to another racer and I think I have a suitable Pontiac replacement. That's racing...
What sorta loop were you running?
I'm just curious because I've always had a theory about those "no drill" loops that use the trans mount as the mounting point. Personally I've chosen to run front & rear loops to hopefully try and reduce any additional damage should the shaft/yokes/joints fail. Sucks about the trans damage. ![]() Bret P. |
Well,I''ll fill you in on my "theory" about those "no-drill" loops.
It long been my suspicion that those no-drill loops tend to do exactly what happened to you when there is a shaft failure,my feeling is the just translate all those forces from the shaft failure,right into the trans case itself,and thus they often end up breaking the trans case/tailshaft housings when there is a failure. That's why I prefer the loops that mount either to the body,or to the frame itself,and not to anything directly tied to the trans itself (like the trans crossmember). I plan on using the Metco front loop for the front of my '72 bird,I got one of their loops for the front of the '70 Lemans/GTO race car,and I gotta say I really like that piece. Not really sure if I'll run a rear loop on the firebird,as it's mostly intended as a street car... For the rear loop on the race car,I reworked one of those universal Lakewood loops that was on the front of the race car when I bought it as a roller. Anyhow,Those are just some thoughts that passed thru my mind when I read that post of yours Johnny,I had a feeling it was a loop like that,thought I might share my thoughts to give you something to mull over when you ponder this whole event. Bret P. |
Brett,
I just spent a good 30 minutes and two glasses of wine laying under the car studying everything. I think you have a really good point and I'lll add that the loop doesn't do the driveshaft alignment any favors either. That loop brings the tail of the trans up about 1/4". 48.5" later, that is a good ways.
#38
Got ya a tranny. It's the BAD BOY spare I built for the Flying Piglet ! Blue clutches, Kevlar bands, all new bushings,etc., Manual valve body. See ya Thursday am. Need address / directions.I'll bring the HSD w/ 930 vac. carb.Killer 60' times set up. If we can, we'll swap the heads to the monster ones I built for you , and the UD solid. Do you have a degree wheel ? What else do you need? Gaskets? So, CALL ME ! Oh, I guess "Region Warrior" can't afford to have his heads ( 13's) done. Never responded to me ! Oh well !
Pontiac Gregg
Greg Merrick Last edited by OINK 1; 08-11-2010 at 09:13 AM. |
#39
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected] 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1972 LeMans 350 Pontiac H/S Drags project Last edited by Johnny406; 08-11-2010 at 10:40 AM. |
#40
You know your bellhousing is broke when: You don't have to unbolt it to pull it out...
