Old 06-20-2011, 07:44 AM
grivera's Avatar
grivera grivera is offline
Originally Posted by 67post3spd View Post
I was told the summit radiators didn't have a lower drain. Is this right? That caused me to go with a 24" universal from jegs that i could see had a provision for a petcock on the bottom left side. $140.00 Today was my first test drive and it seems to have made a huge cooling difference. This is on a 67 with 400.
Mine has a drain, but it's a direct fit radiator. Perhaps the universal types are the ones where one needs to check...
Will Rivera
Old 06-20-2011, 08:32 AM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Can people post part numbers or links. I am seriously buying a new one. Just looking for best price etc..
67 Tempest or GTO without AC,
Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 06-20-2011, 08:46 AM
grivera's Avatar
Dave
Here you go, I paid $279 several years ago- now it's $299...
http://www.summitracing.com/parts/SUM-380456/
Will Rivera
Old 06-20-2011, 10:03 AM
Griffin 55222 bought, will follow up as to its cooling performance..
The Burb Files
Old 06-20-2011, 10:15 AM
roadrage david roadrage david is offline
Originally Posted by T A 70 View Post
By the way, Rodney Red is what I purchased and will never look back.
Same here!!!!!!!!!!!!!!!!
Old 06-20-2011, 10:28 AM
grivera's Avatar
How much?
Will Rivera
Old 06-20-2011, 10:40 AM
Originally Posted by grivera View Post
How much?
269$. Summit does not make a direct fit for the 67 GTO/Tempest. The other thing is that the lower portion of the radiator support is curved. The Griffin fits so well, that I am going with proven fit.
My current rad is most likely clogged. I figured that I am getting an up grade and a new rad. PLus I don't care how careful you are fins get bent etc.. This rad is in rough shape. It is more of a back-up then a primary.
Add the fact that I went from a 2.56 rear to a 3.23 and the added tube size will help.
The Burb Files
Old 06-23-2011, 12:09 AM
The difference between the Griffin 25222X and 55222X is huge!
My 25222 in older (2000 maybe) and when I flushed it I could see rust in it. I think that the crude sitting in the overflow and old rad is clogging it. Made sure that it was not oil,,LOL!!
The only thing is that I had the perfect setup with the MKVIII fan. The core on the 55222 is about 1/2 thicker, due to 1.25 cooling tubes. So I need to raise the assy about 1/2" and make new brackets. Hopefully, I wont have to remodify the lower brackets to "lean" the radiator forward a hair. I wish that I could get a picture of what 1" and 1.25" cooling tubes look like. It is huge!!!!
More to come. I plan on making new brackets this week. New coolant with distilled and some water wetter.
Dave
The Burb Files
Old 06-23-2011, 12:25 AM
imposter's Avatar
imposter imposter is offline
Default Mark 7
what a nice piece if i ever needed another radiator id definitely would buy another
Old 06-23-2011, 11:23 AM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
I got a low budget chinese aluminum radiator for my Grand Prix from radiator express dot com. 2 rows, aluminum, direct fit (almost) for $169. It has worked well for a year so far. This radiator is not as pretty as a griffin, but gets the job done.
Old 06-23-2011, 11:51 AM
formulabird428's Avatar
formulabird428 formulabird428 is offline
Be Cool complete kit (67-69 F/B manual trans) for my 1979 Firebird (A/T). I wanted the 67-69 because they are slightly smaller and have the brackets on the side (didn't want to use the stock-type mounts). I don't need the trans cooler because I have a separate B&M plate cooler (that also keeps trans at 155 maximum).
Previously with a 4-core OEM Modine and a Flex-A-Lite 4000cfm dual fan, car would NOT run anything cooler than 220F.
Put the Be Cool setup on (with the 2-11" Spal Fans) and it instantly ran 175-180. On the warmest days (100F ambient), I'll see temps around 184. At night (60F ambient) if I keep the fans on, I can go down to about 161F.
They are certainly not cheap, but for a complete kit, I don't think you could do any better (IMO).
By the way, this is on 11.25:1 440cid 600hp combo.
Old 06-23-2011, 12:02 PM
grivera's Avatar
Originally Posted by GoGoat View Post
What brand of Aluminuim radiator is perfered? Going in 69 Firebird.
Which one did you decide on?
Will Rivera
