Old 12-28-2012, 11:30 PM
RedDirtRoad RedDirtRoad is offline
I thought the problem was with canceling cam not making contact with the plunger in the turn signal switch. It barely makes contact. the problem was with the green wire coming from the horn relay to the semi circle plug under the dash. The terminal was a bit corroded and the connection wasnt that good. I cleaned it up and its working great now. Just a pain to trace it back to this point but feel great now that my entire electrical system is working perfectly after having the whole car apart. No lost grounding issues! they can be a real PITA!
thanks again to all.
Old 12-29-2012, 11:39 AM
GT182's Avatar
GT182 GT182 is offline
If anyone needs it, here's a good diagram for the assembly. I thought I'd lost it during my XP reinstall but just found it this morning..... after looking all week. Included is the Assembly sheet for a Grant steering wheel and the horn.
Name:	Horn Parts Assembly.jpg
ID:	307616   Click image for larger version
Name:	Grant Wheel and Horn.jpg
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 07-09-2024, 09:25 PM
pmdclassics's Avatar
pmdclassics pmdclassics is offline
Originally Posted by RedDirtRoad View Post
My final assembly is almost complete.
My horn is not working.
I wrung out the wiring and it seems the green wire going back to the steering column has continuity but not completing the circuit.
The plastic turn signal cancelation ring doesnt seem like its making contact with the copper plunger in the turn signal switch
I posted up some pics.
Is something incorrect? should the ring be seated in the column further?
Is there a spring somewhere in your assembly? I also am having a similar problem and trying to figure out what parts are missing. My horn does not work and both turn signals do not shutoff. My 67 GTO came with a standard steering wheel and someone put on a deluxe the horn wires from the spokes are cut off. Also I am wondering if I added the spring to my assembly it would shut off the blinkers.
TODD
Old 07-29-2024, 03:47 PM
Is there a spring in the column assemble as I marked in this diagram??
Name:	markup67 steering wheel.jpg
TODD
