Old 05-02-2014, 12:14 PM
Orion88's Avatar
Orion88 Orion88 is offline
http://www.gtoforum.com/f83/first-re...970-gto-40319/
I know it's on the "other" forum but I hadn't heard about this forum at the time I started my build and I didn't see the point in duplicate build threads.
Old 05-05-2014, 02:01 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
A summary of my OHC L6 project.
http://forums.maxperformanceinc.com/...d.php?t=731313
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 05-12-2014, 01:42 PM
jlwdvm's Avatar
jlwdvm jlwdvm is offline
69 Firebird Track Car...Almost 5 years and counting now, but the project has changed directions a few times!
http://www.pro-touring.com/threads/1...rack-car-build
Old 05-24-2014, 10:27 AM
Tom McQueen Tom McQueen is offline
A big thank you to Mark at LPI for all of his help on this.
Just sold my Procharger stuff and went twin turbo. 2-75mm turbo's, 2-45mm wastegates, 2-50mm BOV's and the turbo friendly solid roller shipped from Steve Morris's shop last Wednesday to my builders shop. We have spent the last 3 or 4 weeks getting everything spec'd correctly. These parts are the only pieces we didn't have to put the complete engine together.
Engine is 555 ci. Car is setup for an 8.50 cert, but already has the X bars on each side in the floor and in the roof. T-400 in a Reid case with a Gear Vendors OD. Looks like we will use a 2.33/1.48/1.00 Coan planetary with either a 3.60 or a 3.70 rear gear. TBD. Rear end is a Mark Williams 9" modular with moly axle tubes and a billet locker.
Art Morrison framed 70 GTO. Rack & pinion Corvette front suspension, 4 link/watts in the rear. Only remaining GM piece of the original car is the body, firewall back. There are pics of the car on this site already. Its appropriate this thread is in the street section because this is primarily a street car. Has A/C.
Old 06-13-2014, 05:06 PM
Doug1's Avatar
Doug1 Doug1 is offline
1979 Pro-Touring TA with a 535 IA 2 and T56
http://forums.maxperformanceinc.com/...d.php?t=755390
Old 12-11-2014, 01:40 AM
gtofreek's Avatar
gtofreek gtofreek is offline
Default My 413 for my 64 GTO
Here's a link to my extreme performance 413!
http://forums.maxperformanceinc.com/...d.php?t=765803
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 03-25-2015, 12:00 PM
HWYSTR455's Avatar
Here's mine, a 70 Judge tribute build out of my LeMans:
Old 06-02-2015, 05:10 PM
Steve C. Steve C. is offline
Current "660 hp" 505 cubic inch street build:
http://forums.maxperformanceinc.com/...&highlight=505
With a link to further details on the engine prior to a cam change, and note my corrected cam numbers after my first post.
Old information here:
Old 06-02-2015, 05:13 PM
A link to a previous 462 street engine:
http://www.pontiacstreetperformance....455sc2003.html
Dyno results: 589.1 CB Torque @ 4400 rpms and 580 CB Power @ 5800 rpm with Performer RPM intake.
Quarter mile with RPM intake: (running 8" converter and 90/10 shocks on the front and no sway bar in place); 1.60 60" times, 10.88 ET at 124.28 mph (date: 11-21-03)
600 hp with a Victor intake. Not track tested.
Old 05-30-2018, 02:54 AM
glhs#116's Avatar
glhs#116 glhs#116 is offline
This is my unintended rebuild of my fairly stock 1971 455HO from my Trans Am. Lots of good internal pics for anyone wanting to see any 455HO internals. The engine had received one decent rebuild before my ownership where it was bored .030 over and the heavy forged Speed Pro pistons were installed with stock rods. Later, about six years ago during my ownership, the crank had split and been replaced with a new Eagle crank that had no prep done, it was simply thrown in the engine by an unskilled shop. They also replaced the rod bolts with ARP bolts I provided.
This build happened by me over the winter in my house because the distributor gear got ground up and sent trash through the bearings. The filter stopped it going through the galleys but it scored the walls and the crank journals.
In this build I took my time and went carefully. I had no machine shop services available so I had a crank done by Paul and sent to me (a used N Pontiac crank). The cylinder bores were in good shape with almost no ridge so I honed them myself.
http://forums.maxperformanceinc.com/...d.php?t=810927
Sam
Sam Agnew
Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it.
Ministry - Jesus Built My Hotrod
Old 08-16-2023, 12:20 PM
1_Wild_Cat's Avatar
64 GTO full restoration from a basket case. Some serious metal fabrication and metal finishing. I hope everyone enjoys it...
https://forums.maxperformanceinc.com...d.php?t=783497
Old 08-16-2023, 12:30 PM
HWYSTR455's Avatar
My 71 Formula build thread, just starting to pick up speed with body & paint:
Project took several turns, the title is no longer accurate...
