Old 04-18-2016, 06:49 PM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by ho428 View Post
I run the restrictive push rods, seem to do ok.
I've thought about hard lines but I'd be concerned about vibration and fatigue.
I had some of this stuff laying around from turbo projects so I used it on the end of the steel drain tubes coming from the heads.
OEM quality, designed specifically to drain oil properly, no vibration issues. No bulky hoses and fittings. Oval flanges easily welded onto a steel pan.
Tubes bolt on to flanges and use proper o-rings. Aluminum flanges could be welded on an aluminum pan. Nice smooth bends and big drain holes.
Tom V.
Name:	turbo drain -1.jpg
ID:	426554   Click image for larger version
Name:	turbo drain -2.jpg
Old 04-18-2016, 08:41 PM
60man's Avatar
60man 60man is offline
Originally Posted by mike leech View Post
Fabricate a aluminum containment pan. Lots more room and a lot easier to work on
That's my next project too.
ECM member.
MANDRA
Old 04-19-2016, 03:46 PM
slowbird's Avatar
slowbird slowbird is offline
Easier said than done. With a cross member going under the pan how would you build one? You would need trays one in front and one behind crossmember wouldn't you?
Old 04-19-2016, 04:24 PM
mike leech's Avatar
mike leech mike leech is offline
Everything worth doing is easier said than done
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 04-19-2016, 04:28 PM
slowbird's Avatar
For once i'd like the easy button. Lol
Old 04-19-2016, 05:56 PM
Vince GTO's Avatar
Vince GTO Vince GTO is offline
Amen with that!
Old 04-19-2016, 07:24 PM
Tom Vaught's Avatar
Boost Engineer
The easy button is the one where you hit the starter and make another pass down the track vs having oil get on your tires and you and the wall make love for a bit. When you hit the wall that is the really "HARD thing" and after that the repair, not figuring out how to make a proper box to catch the oil from the engine on a car with a cross-member.
Tom V.
