Semantics.
I guess it depends on where you seek and find the numbers. It is similar to lobe number 5216 which is a Magnum lobe listed in some sources. And depending on the source, rated 137-138 degrees at 0.200" valve lift. The similar XE lobe 5445 is about 143 degrees at 0.200" lift. And shorter seat timing. A big difference. Or similar to lobe 5240. Which has 0.200" duration closer to the XE lobe. Onward. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 12-31-2016 at 12:07 AM. |
http://www.lunatipower.com/Product.aspx?id=1755&gid=340 Comp's 041 clone (link borrowed): 51-116-3 http://www.compcams.com/Company/CC/c...px?csid=6&sb=0 Crane's 041 clone: https://www.summitracing.com/parts/crn-969681 Howards" 041 clone: http://howardscams.com/i-24079739-ho...ifter-kit.html Isky: doesn't really have a 041 clone (most cams are single pattern). I'm sure, given the specs, they will grind an 041 for you. http://www.iskycams.com/ Crower's 041 clone: https://www.summitracing.com/parts/cro-60919 Melling's 041 Cam: https://www.summitracing.com/parts/mel-spc-8 Bullet Cams: I am not knowledgeable enough to fully "get" their catalog. It appears you pick your lobes and talk with them about your cam---or just talk to them about an 041 cam "clone" and I'm sure they will take care of you. http://www.bulletcams.com/ These are all I could think of. Others will know more.
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
I use the Crower 60919 in my 6X headed 455 and it runs great. So far it has been 7.90s in the 1/8 mile with exhaust manifolds, 3.23 gear and Cooper 245-60-15 radial tires shifting at 5100.
