Old 08-29-2025, 05:53 AM
Judge273's Avatar
Judge273 Judge273 is offline
Do you guys really think they changed the knobs on a year by year basis? Plus they made only subtle changes?
Or was it a manufacturer die difference?
Mike/Illinois
The Following User Says Thank You to Judge273 For This Useful Post:
Old 08-30-2025, 12:52 AM
Ramairnacho Ramairnacho is offline
Default This is a 76 shifter
The later knobs aren't raised. I got both styles for my 78 ta and an early repops.
ID:	656361   Click image for larger version
Old 08-31-2025, 11:36 AM
unruhjonny's Avatar
be careful;
making a statement “this is a 197x part” can lend to muddying the waters.
1970 Formula 400
Old 08-31-2025, 11:43 PM
I wasn't trying to confuse anyone but showing a shifter knob from a 76. I was hoping the gentleman that just bought his 71 would see it and notice it's not a big difference between the 2 and since later ones are easier to find it would possibly save him a few bucks that's all.
Old 09-01-2025, 06:54 AM
Judge273's Avatar
I bought this knob as it matched the one on my 71 TA.
Has a metal raised edge and a fine grain. Matches the interior better too.
Mike/Illinois
Old 09-01-2025, 12:12 PM
65madgoat's Avatar
@ Judge273 - while close to your original, a 1971 would have this exposed ridge below/around the emblem as shown attached here.
And obviously a pretty noticeable difference than the later completely flat emblem knobs.
The one you show, while still a raised emblem version, is likely the 74-76 era or so I believe....
Old 09-01-2025, 07:05 PM
Held for Ransom's Avatar
So, you've seen several like the one you've posted and it's not an oops?
So long, farewell.
Old 09-01-2025, 08:27 PM
65madgoat's Avatar
Yes 100% have.
Old 09-01-2025, 08:33 PM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
'75 shift lever/knob that I rescued from the warranty scrap bin in 1975. Been hanging on my shop wall for at least 40 years.
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
The Following User Says Thank You to HoovDaddy For This Useful Post:
Old 09-01-2025, 09:20 PM
65madgoat's Avatar
Awesome. Yes that is the second mid 70s design - raised emblem but no recessed ridge around it. Thanks for confirming.
Old 09-03-2025, 12:06 PM
65madgoat's Avatar
Confirmed with Teri Moody Reed that this style knob (shown here) was original to the 1974 f-body (up to 1976?) as Held for Ransom &
HoovDaddy also shows.
Still a raised emblem - but not with the recession ridge as seen on 1971-1973 knobs.
Old 09-03-2025, 12:52 PM
Norwood's Avatar
Norwood Norwood is offline
Always my go to when I’m looking for an expert.
The Following User Says Thank You to Norwood For This Useful Post:
Old 09-05-2025, 12:42 AM
Default My raised shifter
I didn't realize there were 2 different styles of early shifters this is another shifter I bought. It's a raised and from what I read it's probably an early one but I'm still learning.
ID:	656707   Click image for larger version
Old 09-05-2025, 01:00 AM
65madgoat's Avatar
Yes that is 1971-1973. Nice find!
The Following User Says Thank You to 65madgoat For This Useful Post:
Old 09-07-2025, 06:15 PM
Then this one is what year since it does not appear to have the raised part in the knob, yet the emblem seems the same being raised with chrome and unlike the flat insert and current reproduction...
Picture of a 17K 1976 Formula...
So long, farewell.
Old 09-07-2025, 06:40 PM
65madgoat's Avatar
Nice Held for Ransom. Exactly what I see on 74-76's.
Old 09-07-2025, 09:43 PM
You keep saying 1974. My '74 looks like my '73. Or are you saying 1974, Muncie vs. BW?
So long, farewell.
  #38
Old 09-07-2025, 10:09 PM
65madgoat's Avatar
You noted "replacement" for your 1974 in your earlier post. So is the photo you posted not the original 1974 knob?
  #39
Old 09-07-2025, 10:21 PM
Correct. The original 1974 had the medallion fall off and was reglued on wrong. So, I found a correct replacement. Which happened to match my early '73 knob.
So long, farewell.
  #40
Old 09-07-2025, 10:41 PM
65madgoat's Avatar
The emblem it appears is likely the same on 1971-1976 ---- it is the knob itself that is different as the emblem on the early knobs exposes the recessed ridge and pretty much fills in the top on 74-76.
