We wasted 2 years waiting on you to do something with em. You may be a good engine builder, but as we all now know you really aren't capable to do r&d work. You're much better at picking up the phone and using someone else's product. You and your brother from another mother Lou are the biggest detriment to these heads. BTW you are the ONLY ONE to go slower with these heads. Just sayin
Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far |
OHDAMN!!
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
LMAF AGAIN!
Thats twice in one day(haven't LAF in weeks). Thanks guys!
Is the Pro-Stand class for NA combinations only? Any extra points if I paint the stand Pontiac blue?
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
I hate to admit this on the forum but I have to throw the towel in. I was getting it ready to fire up late last night and found out my t400 case is cracked between the fittings. Not sure when it happened but I think its when I dropped the cooler on the floor. I had it still hooked up and the cooler was ziptied up out of the way and it broke loose and yanked the hoses pretty hard since the car was 2' in the air. I suspect it was already cracked and this could have just made it worse.
I had a very small leak last year which I thought was a pan gasket. Im thinking it was weeping from it and I just couldnt see. Guess Im bringing cold beer for the ECM since my cv-1's wont be there. ![]() I have M&M local to me so I might call and see if they can get me done in time. Its still possible..... |
Here is a link to a post I made on YB about how the aero packet can cause ET and MPH changes.
http://www.yellowbullet.com/forum/sh...558895&page=19 Post #278 Stan
cant believe still no cv1 cars!!! if Robin was there I would go and give him a run.
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046s 1.079 4.52 155.15 3000 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! 7.17 @ 188 1/4 mile (2024) Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
FIXED |
YIKES!!!
70 Formula Old engine: 467 HO headed 6.79 1/8th mile @ 101.87 no N20. 1.44 60ft 6.23 1/8th @ 111.83 w/nitrous 1.37 60ft New Engine IAII 535 Calvin Hill Eheads Few test passes made. Tore it up. Just got it fixed. |
I would like to see a set of CV1 go 7s in my lifetime!
just sayn |
![]() Brian
Boobs & bacon
by the same logic....the e heads came out in the mid 90's...I'm thinkin' 1995....so....15 years??? |
how long ago did butlers go 7s? David did it with e heads with his 96 trans am a long time ago. EHTTFMF!!!
A well put together turbo combo isn't going to care what heads are on the engine.
http://www.youtube.com/watch?v=ZFYJ-1Mtftc |
simple question, really. |
If someone can run 6s (Marty P) with a cast iron 62 Traditional Pontiac Head, I would hope that you could break into the 7s with a CV-1 Head with boost.
![]() Tom Vaught
So after a little over 3 years of build time I hope to be in the 7's. I suspect I wont stop pushing to go faster. If a "good" engine can make 2000hp with these turbo's, that should be enough hp to get a light car in the 6's. How much did Marty's car weight? If he went 6's with 1600hp I'm betting that was a pretty light car. 2600ish..? |
