Closed Thread
Old 07-18-2015, 08:46 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by Jack Gifford View Post
I like to think that the M/T hemi heads did- the only Pontiac to ever take Top Eliminator at an NHRA Nationals. I consider that a "record".
MTHHTTFMF!
Go fast, see Elvis!
  #622
Old 07-18-2015, 08:48 AM
PAUL K's Avatar
Originally Posted by Fast 69 View Post
Porting is allowed in Super Stock class so those heads aren't "as cast" either.
QUOTE=PAUL K;5434533]Factory cast heads have in Super Stock... just saying.
[/QUOTE]
They have changed rules over the years. There have been a lot of "as cast" factory heads win races and set records.
Go fast, see Elvis!
  #623
Old 07-18-2015, 09:13 AM
PAUL K's Avatar
Originally Posted by Money Pit View Post
I don't believe Jack did it but once. Ed McGuinn has done it multiple times and not on the east coast. And on one kit.
Is Ed the gentleman with the Ehead powered, dark colored 79 Trans Am?
Go fast, see Elvis!
  #624
Old 07-18-2015, 09:17 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Yes
First Pontiac powered street car in the 7's
[email protected]. 3460#s
  #625
Old 07-18-2015, 09:20 AM
LiL Jack's Avatar
Originally Posted by twooldgoats View Post
Maybe you should save some space for spare parts.
Jim
The new motor has been great this year. Taking baby steps with the tune up then adding more power figuring out the chassis, transmission and rear gear ratio that has been the hard work.
  #626
Old 07-18-2015, 10:14 AM
Originally Posted by GTO Dan View Post
Back to the thread topic...how many of you think, regardless of the outcome of the race that most, at least those that posted in this thread, will not change their opinions.
You may be right on that point.
However, it would be interesting to see some NA passes on both combos. Seems a lot of non believers of Fulton's NA HP. No one with a Pontiac that I'm aware of has made 1100 plus HP NA at 13:1 compression. Little Jacks NA base power ???
Would be interesting to see how much power adder they added.
Possibly some opinions might change then.
  #627
Old 07-18-2015, 10:40 AM
GTOGEORGE's Avatar
You can't compare Power added engines without the power adder...........that would be silly. The engines are made for the PA addition. I would like to see at least 6-8 runs at Norwalk from BOTH these cars without any problems.........then I will be IMPRESSED!! I hope both cars run well and have NO problems.........we'll see.
GTO George
  #628
Old 07-18-2015, 11:23 AM
goatracer goatracer is offline
Yep, like George said, them racing na is pointless. Running a nitrous car na with any converter specd for a heavy hit will only bring naysayers rushing to Wallace calculator and calling bs. Best to line em up spray to spray and runwhatya brung.
  #629
Old 07-18-2015, 11:57 AM
JSPONT's Avatar
JSPONT JSPONT is offline
I can't afford either head so my opinion won't matter.LOL
  #630
Old 07-18-2015, 12:54 PM
I agree racing each other NA is a waste of time. That wasnt what I would like to see.
I know the ET would be down because of convertor etc.. MPH down some maybe but possibly closer to gauging NA power than ET would be.
In a MUCH slower car my mph stayed pretty close to best as I dialed convertor, gears, chassis, and launch and eventually ET'd what my mph indicated it should. Without touching engine or its tune ET dropped nearly .3 while mph barely gained.
I hear you on the rush to Wallaces calculator. Some will be going there regardless of N2O pass or not lol .
  #631
Old 07-18-2015, 01:34 PM
You can buy same ported casting as Fultons CV1 (max cast 330) with same valve job, same flow for far far less than a billet head + porting + valvetrain. It IS NOT a one off port. Bill digitized it over 3 years ago. Dick is not only one with this port, he finished his build sooner. Depending on how you intend to use it you might not need the shaft rockers or need as high a level valvetrain. Options obviously affect price. You can opt for lesser or greater port capability and other options as best fits your application.
And yes I get the budget thing. Its still going to be awhile before I can buy the entry level cv1's to replace my iron heads. With turbo's it just not a high priority.
  #632
Old 07-18-2015, 02:47 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
I get that. That's what I've been doing with my supercharger set-up as well, but with 5000' to 6000' density altitude this summer.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #633
Old 07-18-2015, 02:50 PM
You go back even further than I do, Jack. And I bet you were paying more attention back then, too.
Jim
7.75 @ 178 pass:
  #634
Old 07-19-2015, 12:30 AM
68azbird 68azbird is offline
Jim
You need to move the operation up the road a bit where the DA is 2000' - 3600'
  #635
Old 07-19-2015, 07:12 AM
Tom Vaught's Avatar
Boost Engineer
GTO George
TRUTH!
That would be a good evaluation of the capabilities of both cars/drivers/race combinations on the same track, same week-end.
Tom V.
  #636
Old 07-19-2015, 11:14 AM
I may yet, but it's exactly a hundred miles from my door to Wild Horse Pass and less than 25 miles to SIR.
Jim
7.75 @ 178 pass:
  #637
Old 07-19-2015, 06:08 PM
wreckmastr's Avatar
Making laps......
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
  #638
Old 07-19-2015, 06:38 PM
GTOGEORGE's Avatar
Lots of Pontiacs out there making laps!
GTO George
  #639
Old 07-19-2015, 10:46 PM
BADDTA's Avatar
BADDTA BADDTA is offline
Originally Posted by wreckmastr View Post
Making laps......
That looks bad a$$!!
Brian
Boobs & bacon
  #640
Old 07-19-2015, 10:56 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Making laps......
I see you post the black car on fb. Is that your car?
How fast has the purple car ran this year? Will it be at norwalk?
Closed Thread
