Old 02-11-2015, 04:38 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Default Another old thread that I won't let die...
Originally Posted by Jack Gifford View Post
... building a four-cylinder engine for the lakester, using my spare M/T hemi head. If I decide to go this route, it will differ from a Tempest in many ways- hemi head, DOHC, aluminum block (sitting upright), etc....
Some recent progress to report- see my post of today in the 'RACE' forum ('Guessing game: M/T hemi flow').
  #642
Old 02-21-2015, 07:53 AM
blueghoast's Avatar
Originally Posted by c5farmer View Post
Thanks for all the nice comments about our car. It will be fun, nothing like the sweet sound of a ropeshft spinning away!
Doug, the radiator is a swap meet special designed to fit a big block '68 Nova. It fit pretty well and measured just under 19" x 26". My other car uses a Griffin universal fit 19x26 but required a little triming of the radiator support and lowering the bottom mounts to fit. Both have driver side top inlet hose application and require modifying the shroud.
The junction block is stock to the 63 v8 cars. The junction block wiring schematic is on page 11-4, figure 11-3, of the 63 Tempest Chassis shop manual. Most of the blocks I have found are cracked on one of the mounting ears. If you find a good one, get it.
Hey Jerry; Did you see the video of my blower motor in the race section.
It's under new power plant. Just to let you know.
GT.
  #643
Old 02-21-2015, 11:17 AM
c5farmer's Avatar
c5farmer c5farmer is offline
Default Blower engine
GT, your engine looks mean and sounds "over the top". It should provide a driving experience in your Trans Am when you hammer it! Nice video by Todd, too. Looks like the cold weather hasn't slowed you down.
My engine is on the homemade test stand waiting to be started and broken in as soon as we get a little warmer temperatures. I ran across a guy on facebook that has the same blower set up on his Pontiac, so have been getting tune up info from him. Then it is going into the hot rod Tempest.
ID:	390854   Click image for larger version
ID:	390855   Click image for larger version
  #644
Old 02-21-2015, 10:58 PM
Paul Yeaman Paul Yeaman is offline
Default Blowing!!!
Hi Jerry,
'Looks like a "Ticket-Getter" to me! When will you install it in the car?
'Making some progress here - the disc brake mod' is complete except for connecting the new brake hoses and refilling/bleeding the system.
11 guitars on the bench!!! 'Just returned home from a Guitar Show in Grand Rapids . . . 'long day!!!
You and Susan keep warm. 'See you in the spring,
Paul
  #645
Old 05-05-2015, 09:35 PM
heater63's Avatar
heater63 heater63 is offline
Default My Wife's, it's getting close
Just brought out to go get a roof put on.
"If you aren't first, your last." Ricky Bobby 2006
  #646
Old 09-08-2015, 08:41 PM
c5farmer's Avatar
Default just about ready
The 63 hot rod is just about ready to hit the street again. It has been an adventure changing from a 400 ci D-port engine to a 462 ci O-port engine. The biggest change was exhaust and oil pan interference. Gave up on expensive headers and went with RARE ram air exhaust manifolds. The 2.5" outlet ones required a couple notches in the crossmember, but fit nicely every where else. Also installed a Tempest Guys direct fit radiator that is good for cooling over 600hp.
ID:	407657   Click image for larger version
  #647
Old 09-08-2015, 11:47 PM
TempestFugit's Avatar
TempestFugit TempestFugit is offline
Awesome!... looking forward to seeing it at Norwalk maybe someday!?
Old 09-09-2015, 06:51 PM
indiantony indiantony is offline
Could you post a picture of the notches in the crossmember? Im thinking of getting a set of those manifolds. Thanks
Tony
  #649
Old 09-10-2015, 06:50 PM
c5farmer's Avatar
Default xmember notches for RARE 2.5" manifolds
The only area that really needed notched was at the bottom of the cross member where the side and bottom meet on the driver side. The engine has to be postioned as far back as the motor mounts and tranny cross member allow. I even added some space with a die grinder at the back of the crossmember/engine mount slots. Hope this helps.
ID:	407837   Click image for larger version
  #650
Old 10-12-2015, 12:06 PM
ahnuld's Avatar
ahnuld ahnuld is offline
Default New autogear m22w in car now
New autogear m22w in car now. Love it
63 Lemans ride along and drag race.
https://www.youtube.com/watch?v=XMJHMPx7KAQ Gear Jamming
https://www.youtube.com/watch?v=mw7KPRASomg At the track
  #651
Old 10-12-2015, 01:17 PM
c5farmer's Avatar
Default m22w
Is the gearing the same as a muncie m22? Bet it is smooth shifting!
  #652
Old 10-12-2015, 11:01 PM
ahnuld's Avatar
Yep basically the same. It shifts so nice now. Loud as hell with engine alone never mind the whine of gears on top of it. Love it. Gonna take it to track in spring for sure.
  #653
Old 11-04-2015, 04:01 PM
tom s tom s is offline
As some know I bought a garage find 63 tempest conver 4 cyc 3 speed car.Just got paint on yesterday.They will color sand and polish tomorrow and will be home friday to start putting back together.
ID:	412240   Click image for larger version
ID:	412241   Click image for larger version
ID:	412242   Click image for larger version
ID:	412243   Click image for larger version
  #654
Old 11-04-2015, 07:31 PM
c5farmer's Avatar
Default Looks Great
Tom, The garage find looks smooth and bright. You will have quite the looker when it is assembled. The color is one I don't see very often and is original to the car. Like the 3 speed manual/195 ci combo.
  #655
Old 11-04-2015, 08:10 PM
The real unusual part is the lady ordered the very cheapest no frill body but put the deluxe bench seat interior with a padded dash and deluxe clear wheel in the car.Also had a all transistor AM push button radio.Much diff from any other 63 tempest radio I have ever seen.Tom
  #656
Old 11-04-2015, 09:38 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Can't wait to see it in person, maybe next Seal Beach show perhaps.
  #657
Old 11-04-2015, 09:41 PM
Im am planning on having it at the Enderly show on sunday the 29th.17th street and the 55 freeway.First and last sunday of the month.Tom
  #658
Old 11-05-2015, 02:06 AM
More of a "mirror finish" than a '63 had when it was new!
  #659
Old 11-05-2015, 11:30 AM
Jack,im hope it looses some of it after it is color sanded and polished.That is why I chose single stage.Tom
  #660
Old 01-05-2016, 09:39 PM
heater63's Avatar
Default This winter project
I have started a much needed body refresh, I am growing partial to the primer look.
Happy New Year everyone
Heath
