Old 03-08-2010, 07:22 PM
Brewster's Avatar
Brewster Brewster is offline
Car looks great Steve and hope our travels cross soon cause I'd love to see it in person.
Norwood, You should start producing those flare protectors for us to buy!
  #1022
Old 03-09-2010, 07:13 PM
njsteve's Avatar
njsteve njsteve is offline
Another random helpful hint: I used some of the extra 3M clear protective material and placed a 1 inch tall by 10 inch wide strip in the exact area when the base of the license plate frame would rub the fiberglas panel. I also used several washers under the two mounting bolts for the license plate assembly hinge to space it out about 3/8ths of an inch from it's normal position. This allows the license plate and original dealer frame to clear the fiberglas tail panel without gouging it when I fill the tank with gas.
  #1023
Old 03-09-2010, 07:15 PM
njsteve's Avatar
I'll take you up on that as long as I can trade you for one of your 73 SDs.
I won't be greedy, I'll take the automatic! :-)
  #1024
Old 03-09-2010, 08:24 PM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
Thumbs up
there's that plate frame,looks sweet!!!!
Great job Steve,keep it up!!!
  #1025
Old 03-09-2010, 08:54 PM
Steve,
I get my M35 serviced at the Infiniti dealer in Roseville. It's right across the street from Reliable Pontiac. I was going to snap a pic for you but this is in the auto mall, which is fairly new. What is the address on your PHS? I cold check it out and see what is there now.
  #1026
Old 03-09-2010, 09:32 PM
njsteve's Avatar
Back in '72 they were at 105 Vernon Street, Roseville, CA 95678.
I'd love to see a photo of the old location!
  #1027
Old 03-09-2010, 10:04 PM
Transamric's Avatar
Gotta love Google Earth! Looks like the building on the corner of Vernon & Jefferson is vacant. At least it was on the day the "Google Car" drove by snapping pics.
  #1028
Old 03-09-2010, 10:12 PM
I have a friend who lives near there so the next time I am over there I'll get e picture for you.
  #1029
Old 03-10-2010, 12:30 AM
x-bird2 x-bird2 is offline
I see a "Norwood" part opportunity .... I need one of those little finger handles for my rear plate mount ....anyone else??
  #1030
Old 03-14-2010, 12:42 PM
Steve,
Here are some pictures of Reliable Motors as it is today at the Roseville Auto Mall. It is only a few miles (as the crow flies) from the old Vernon St location. I do not know when they moved out there.
Chris
ID:	200124   Click image for larger version
ID:	200125   Click image for larger version
ID:	200126   Click image for larger version
ID:	200127   Click image for larger version
  #1031
Old 03-14-2010, 12:45 PM
105 Vernon Street today.
ID:	200129   Click image for larger version
ID:	200130   Click image for larger version
ID:	200131   Click image for larger version
ID:	200132   Click image for larger version
  #1032
Old 03-14-2010, 12:53 PM
More pictures.
ID:	200136   Click image for larger version
ID:	200137   Click image for larger version
ID:	200138   Click image for larger version
ID:	200139   Click image for larger version
  #1033
Old 03-14-2010, 12:55 PM
A few shots of the surrounding area. The old train is across the street from 105 Vernon St.
ID:	200141   Click image for larger version
ID:	200142   Click image for larger version
  #1034
njsteve's Avatar
Too cool!
Now all we need is a time machine.
Thanks!!!
  #1035
Old 03-14-2010, 12:56 PM
njsteve's Avatar
Got the rear spoiler installed today. Took a while to get the three sections lined up with each other while also fitting properly on the rear quarters. The key is to use a small circle of body dum-dum on each mounting pad so the sections can compress the dum-dum and settle properly instead of just riding directly on the quarters and trunklid.
It also took a while to get the center section of the stripe measured and lined up correctly prior to installation. Measure twice and apply once is the rule... except when you measure ten times and the math just doesn't work out. That was, until I figured out that the top of the center section is about 1/2" wider than the base. DUH!
Nice rear end!
I always liked the look of the 70-73 'birds. Pontiac got the look just right.
So now at least the back end of the car is finished! If only I could get the shaker, hood, nose, valance and front spoiler painted and installed, then the car would be done. And then I can crown the acheivement with the installation of the restored steering wheel that has been sitting in my closet for 4 years now...if I can still find it.
  #1036
Old 03-14-2010, 01:59 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
that looks incredible Steve, great job on all the smallest of details, it won't be long now on the front end!
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #1037
Old 03-14-2010, 02:21 PM
keepat's Avatar
keepat keepat is offline
Steve,
Wow! Looks great! And you’re right best looking rear of any car built in the 70’s
Pat
  #1038
Old 03-14-2010, 02:43 PM
CaptCrunch CaptCrunch is offline
outstanding job getting the spoiler to fit so well............beautiful car.........
  #1039
Old 03-14-2010, 05:55 PM
I guarantee you not one of these cars ever left the factory with a decklid to body or spoiler fit as nice as this one. Beautiful!
  #1040
Old 03-14-2010, 08:53 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Wow, my trunk spoiler and endcaps are a mess as far as alignment goes. Care to share the method of your madness? Was most of the adjustment in the trunk or both trunk and the ends? Just think their is not much room to move the ends around.
Also what is body dum-dum? Thanks...
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
