#101
I beleave he had to pull it cause of a rod knock I think his thread is in the street section of the tech forum
#102
Karl |
#103
I hate it when that happens
www.bowhanger.com 468 poncho powered 66 cutlass 77 Trans http://s1059.beta.photobucket.com/us...rnout.mp4.html |
#104
http://s668.photobucket.com/user/tam...00000.mp4.html
Idle turned up about 1500 rpm |
#105
Yep pulled it cause of what I believe to be a rod knockin, not sure what mufflers are on it. Its a pypes kit a bought a FEW years back from a PY member with the Hedman Headers
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 01-22-2014 at 09:36 PM. |
#107
Either way man it sounds really good I hope the next Round Goes a lot better for you
#108
406 TII intake Holley 670 HEI
Stock manifolds Pypes 2.5" downpipes Pypes 2.5" intermediate pipe Summit Super Turbo mufflers Flowmaster 2.5" tailpipes. http://www.youtube.com/watch?v=U7cmyzWJ9Gw
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
#109
What cam specs did you have when you ran the Pypes system? Did your Pypes system have the transverse muffler? |
#110
Its nice to see more post getting up in here
#111
Why isn't this stickied?
1972 Pontiac Lemans 350 Qjet Summit 2800 |
#112
#113
1970 RAIII 400 Stock cam, original RA manifolds, 2.5 inch pypes downpipes into Walker/Dynomax/Thrush 2.5 Crossflow System. Very affordable with a very good fit, sound GREAT. This will be the third year I have had this system on my car and I'm very happy with it.
http://www.jegs.com/i/Dynomax/289/89021/10002/-1 take a listen http://www.youtube.com/watch?v=T10N0...ature=youtu.be |
#114
Was the whole idea when i started this thread....
#115
My current 66 and my last 66
http://www.youtube.com/watch?v=DtiW0NXzSzo
This is my current car, 71 455, 6X-8 heads, 66 tripower, ram air manifolds, pypes x-pipe sys with huge (20" case) 17749 Dynomax Super Turbos and flowmaster tailpipes, still getting tune dialed in during this vid, but this car is quiet enough inside to drive some distance comfortably on the highway http://www.youtube.com/watch?v=lE02rPqnJFY This Fontaine (clone) was sold several years ago 67 400 , 670 heads, (unknown cam specs) , 4bbl , headers, 2 chamber flowmasters, Great throaty idle, but too loud out back and inside for my taste |
#117
Sorry, reposting to correct the links for each Fontaine Blue 66 http://www.youtube.com/watch?v=IclrzQCz11A Barrier Blue 66 http://www.youtube.com/watch?v=rabD9LptfZc |
#118
Cars look and sound good
#119
Here's my old one, still had the 2004r in it, slipping. Dougs, 2.5 pypes the whole way, with X, 20" Goelich mufflers.
http://www.youtube.com/watch?v=R2Od_KQq1ms Was slightly leaning out on the top end too, but you get the idea. .
#120
http://s668.photobucket.com/user/tam..._0229.mp4.html Sorry about it being sideways!
