Murf |
Used a hack saw and cut mine a bit.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
Barry |
I had old studs and guideplates from my E heads when I switched to a shaft and they fit fine even before the tabs were popped off. But the first one before I popped tabs off felt a little "tight" at the bottom.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Yes, even with the heli-coil tangs broken off they are still about an 1/8 inch short of seating tight against the guide plates.
Tim Corcoran |
I trimmed the studs for the pair we have running
Many versions of the bbc 7/16 stud out there I went taller to get geometry where I wanted it Cutting a little off the bottom Was not a big deal breaker for me These are good Budget heads anyone that thinks otherwise hasn’t driven a car with them on
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
I want to think I use ARP 7102s.
I had to shorten studs to fit factory iron heads just a month or so ago.
Edelbrock guide plates are thicker. That would help with this issue but like a few others I just trimmed up the studs. I have run into this on iron heads also.
Wouldn't Speedmaster be able to give you the spring rates? I'd give them a call.
Tim Corcoran |
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
I noted the springs linked above are the only set that are 1.450" O.D. at 1.800" installed which is listed for their Pontiac cylinder heads.
I presume they would use the springs they sell. Also noted the 1.800" - 1.060" Coil Bind info listed does not correlate with their 0.580" max lift stated. Side note, regarding the 1.800" installed height stated. I've seen two posts regarding two different sets of heads received and they were measured at 1.780" and 1.825" installed height. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 12-06-2023 at 01:10 PM. |
Any actual drag data or dyno numbers on these heads? I haven't seen any.... just forum discussion? Somewhere someone must be running them?
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
i seen the owner of pontiac speed shop mention he was near the 800 mark on fb |
Nothing from them comes with instructions ? Who sells a fuel pump with no instructions ? Not even a "in-out" on the pump or what amp fuse to use. The fuel filters, one 8AN has O rings on the caps. When you tighten them by hand you can not feel the O ring contact the tube. I think it will leak unless I change it to O rings that seal. The other filter is a 3/8" hose deal and the nipples are barely long enough for a hose clamp and the little bump on the end is not big enough for my liking. It was 8 $ so what the heck. Not saying none of this stuff will not work but you have to double check everything. Simple instructions would be nice. I guess they feel they can just copy what they want and put it out there without any. Hey, they stuff was cheap but the you get what you pay for rule applies. |
Probably, but was looking for actual results if anyone had measured them on a tester. I have no doubt SM can give me specs but I have trust issues. Will likely measure them myself prior to doing anything but was just curious if anyone had some existing experience.
Michael 1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished! 1979 Trans Am - low-buck drag car project for when I retire |
Tim Corcoran |
"That's why I ordered mine bare, so I could control everything and get what I want/need for my specific application"
Winner, winner, chicken dinner ! .
| The Following User Says Thank You to Steve C. For This Useful Post: | ||
Steve,
This shows that many valve springs have those same differences listed. Stan
| The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
Understood. But doing the
Math with it just doesn't jive with the max lift.
