Old 11-01-2013, 11:48 PM
YNOBIL's Avatar
YNOBIL YNOBIL is offline
Originally Posted by RedDirtRoad View Post
More Photos
Just saw your thread and you car looks great. My only criticism is the shot of your spare tire. A factory tire would never have any kind of a sticker on the tire tread. They would have some kind of color coding stripe on the tread but never a stick on label. Great car!
Bill Nawrot (Wino Bill)
1972 GTO Hdtp One Owner, GTOAA "Concours Best Original" 2007, 2013, and 2019
Auto-Biography http://oneownercollectorcar.com/inde...to-bill-nawrot
HPP Sept. 2014 https://www.hotrod.com/articles/1972...-gee-no-g-t-o/
YouTube MCACN 2014 http://youtu.be/1IPQVPevbxU
1967 GTO Conv
  #142
Old 11-02-2013, 06:44 AM
1967SC's Avatar
1967SC 1967SC is offline
Default Radiator
I didn't go through all 8 pages ,but was wondering why you have a later style radiator in the car.
I noticed the trans cooling lines go into the right side of the unit.
Nice job on the project,btw.
Good luck
1967 GTO Sport Coupe
49,xxx orig.miles
Champagne/Parchment
30 Original Owner Ordered PHS Documented Factory Options
Second Owner
  #143
Old 11-02-2013, 07:38 AM
RedDirtRoad RedDirtRoad is offline
Yes you are correct. I just recently learned that same info too. I think I will leave the label on the tire and just turn it to the back out of view if I get it judged but have it shown in view at car shows just for effect since most dont know anyway.
thanks for the feedback.
  #144
Old 11-02-2013, 07:40 AM
Good luck
The radiator is an original radiator. The trans lines are on the bottom as they should be.
I am using ram air manifolds and the trans lines run up the frame and over the control arm.
The Following User Says Thank You to RedDirtRoad For This Useful Post:
  #145
Old 11-02-2013, 02:19 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Default Window fuzzies
Been working on the GTO the past few weeks now that work calmed down a bit
I installed sound barrier on the floor, roof and behind rear seats.
Intalled the L/S fender and innerwheel well permanately. Got the gaps and body line perfect.
Installed door weatherstriping and roof rail weatherstriping, I got the doors shutting perfect now. Its all in the right weatherstriping.
Disassm. the window regulators, cleaned and greased them and relined the channels with new correct fuzzies.
Installed all the AC seals on the radiator support.
Installed all the brake lines and booster, Bled the brakes. Car starts and runs strong. Just havent actually driven it yet or moved it.
Next on the list is the A/C lines, condenser coil and drier. Once thats done I can install the R/S front fender.
RDR
Hope I am not asking this question twice, as I have not read thru your whole thread yet. What material did you use to recover your window fuzzies, and where did you find it. I am wanting to do the same to mine as it seems the repop ones are not correct and do not fit well from what I am hearing from others. VERY NICE 67 by the way!!!
Thanks.
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
  #146
Old 11-02-2013, 05:25 PM
What fuzzies are you talking about?
The outter ones, inner ones or the fuzzies on the window tracks?
  #147
Old 11-03-2013, 01:28 AM
Sorry, the outer and inner ones.
Thanks.
1976 Formula 350.
1968 Olds 442.
1971 TR6.
  #148
Old 11-03-2013, 08:00 AM
1967SC's Avatar
My bad,I thought that picture was of the top rad hose,just noticed it was the bottom hose.Sorry.
Btw,did you buy the trans cooling lines specifically for the R/A manifolds or did you re bend ?
I'm going through this now,as I changed my manifolds to R/A type after I purchased my trans cooling lines.
PS Could you possibly post a picture of the lines where they cross over the control arm ?
49,xxx orig.miles
Champagne/Parchment
Second Owner
  #149
Old 11-03-2013, 02:37 PM
Here are some pics of how the ram air lines are routed.
I bought the lines specifically for a ram air car.
The bracket for the lines that are normally located on the top of the frame must be relocated to the side of the frame as shown in the second pic.
ID:	341722   Click image for larger version
ID:	341723   Click image for larger version
  #150
Old 11-03-2013, 11:50 PM
Simpson Simpson is offline
Eric,
The rear axles were assembled and unpainted on the assembly line but once the car was completed they reach under the car and sprayed everything satin black.
After all the work I have done to restore the car I just can paint it black overspray like the factory did. I guess I will just have an over restored car.
Old post but the blackout process was done before the body drop. Cheap asphalt based paint that was drizzled on the A arms and rear end.
Very nice job on the restoration, although the chassis decal stickers are a little overboard for my taste.
  #151
Old 11-09-2013, 04:20 PM
I took the GTO out today for its maiden voyage. I went 15 miles round trip to a morning Cars and Coffee here in South Jersey. Not one hiccup. The car ran flawlessly.
A friend of mine shot a few pics of the car too.
ID:	342484   Click image for larger version
ID:	342485   Click image for larger version
  #152
Old 11-09-2013, 05:10 PM
arbys's Avatar
arbys arbys is offline
That's sharp and I love that color.
  #153
Old 11-09-2013, 05:53 PM
Satyr1966's Avatar
Satyr1966 Satyr1966 is offline
Looks great! Very nice fit & finish!
By diligent effort I seem to be prolonging my adolescence to total absurdity. John D. MacDonald
  #154
Old 11-10-2013, 01:03 AM
Thanks everyone.
New pics to follow soon
  #155
Old 11-10-2013, 02:00 AM
This thread is now dedicated to John Howie.
John was a good friend I met by accident. Once I met John I knew he was a car guy and really had a passion for the cars he worked on. John did all the body work on my GTO.
It was never about the money he could make off of doing the work on a car, rather the joy and satisfaction he saw seeing the car come to fruition. He had hands of gold!
John is also shown in so many forums my other friends had projects going in.
He restored a '68 Road Runner(DodgeCharger.com), a '64 GTO profiled on here, a "69 Daytona Charger(DodgeCharger.com), a Ferrari 308 (Ferrarichat.com)and numerous other projects. Sadly John passed away suddenly on October 14, 2013. He will be missed. I am at a point in my life that I have now completely given up on restoring cars without doing this with John.
I plan on showing my car and once I have it certified concours gold, my trophies will be given to his wife and family as token of my graditude and appreciation for the extraordinary work he did on my GTO.
  #156
Old 11-10-2013, 02:16 AM
Thanks everyone.
2 more. I will have more soon once my Photog, Mike Mauro edits and sends them to me
  #157
Old 11-10-2013, 08:37 AM
1967SC's Avatar
Were those taken in Mt Laurel ?
Would love to meet up with you when I get mine back on the road.
Looking forward to more pictures.Looks awesome.
49,xxx orig.miles
Champagne/Parchment
Second Owner
  #158
Old 11-10-2013, 12:24 PM
Yes in Mt Laurel, NJ
We meet up there every other Saturday morning.
Any and all types of cars are welcome. Its a great group of guys just hanging out talking cars.
Anyone from the NJ/PA area is welcome. You should stop by and check some cars out even if your GTO isnt finished yet
Here is the link for more info
http://highoctanesj.com/
  #159
Old 11-11-2013, 07:12 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Your car looks great.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
  #160
Old 11-12-2013, 08:28 AM
Thanks Tod,
It was a real joy to finally drive the car for the first time last Saturday.
I have a car show to take it to on Thanksgiving day then it gets put in storage for the long winter. This spring I will hit the car shows and see how it does.
I like the B/W photo the best, it gives it that old retro look complete with my old plate on the front bumper that was my fathers from his 1967 Catalina
I got alot of thumbs up from older guys that remembered these cars back in the day and I got a few thumbs up from younger kids too. Its nice to know the young guys still like these cars instead of the import tuner cars.
2 more
ID:	342840   Click image for larger version
