#1941
Here's the pics, fixed.
Not sure 1/4" would make that big of a difference, but ok. And I was thinking it was 'scrubbing' on the body or something. Scrubbing on a dip or rise in/out of a parking lot or driveway is nature of the beast when you lower a car. You get one more person in there and that 1/4" will go away. .
#1942
This is the Hotchkis install doc:
https://hotchkis-files.sfo2.cdn.digi...ions/2202F.pdf I don't see any 'adjustments' that can be made, except for the amount the end links are tightened? "12. Tighten end link nut to the point where the end link bushing’s diameter is just larger than it’s support washer." .
#1943
That’s what I meant. Adjusting the end links. I’m sure I had them in a bind before. I had them tightened way past the recommendation under the impression that more is better
The Following User Says Thank You to 64speed For This Useful Post: | ||
#1944
You are right that 1/4 of an inch goes away but it doesn’t really scrub it’s just if you hit a dip or something it bottoms out. I am gonna get the UMI part number 4048 springs I think. One thing I am humble enough to admit is that you gotta be careful what you wish for. All the trick stuff doesn’t always add up to a great experience.
#1945
Do you know which ones you have now? They make a factory height, 1" drop, and a 2" drop spring.
The rate is 530lbs for all of them. If you bottom on dips in the road at speed, you need more. They rate them for chevy small AND big block, and Pontiac 400s. That's a pretty wide spread and doubt they are optimum for any of them. It's not really a 'be careful for what you wish for' thing, it's a 'be careful what you buy' thing. A red flag for me is when they list the same spring for SBC & BBCs, among other things. .
#1946
I have the 2 inch drop. I called UMI about the 4048 set and they said it was truly stock and would make the ass sag. I don’t want that so I gotta do some shopping
#1947
Call Global West. You won't be disappointed. And, if you don't like them, they will swap them out for free.
The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
#1948
I have the full UMI Stage 3 suspension kit in my '66 with 1" lowering springs (p/n 4050) and I think the ride height is pretty much perfect for a "normal" stance. No bottoming out, no front tire contact with front wheel openings (with 26.1" tall 235/60R15 tires) & wider front track due to disc brakes. No issues. This photo is from two months ago before I got the front & rear windshields installed. No change to ride height with glass in, and car is now at full weight.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 12-12-2023 at 01:18 PM. |
The Following User Says Thank You to ZeGermanHam For This Useful Post: | ||
#1949
Can you post the flow sheets?
#1950
Carpet is in. Now I just gotta figure out what I want to do for a custom console.
#1951
I bought a set of UMI one inch springs. Should put me where I want to be.
#1952
Ok I am at a loss. The interior is mostly done (headliner and a few button up items) but the car still has a lot of road noise and I’m not talking about exhaust or anything but more like when I sling a piece of gravel up in the wheel well going down the highway it sounds like it rattles forever. If I hit something like a pothole and bounce the car it sounds like the trunk is a giant echo chamber. I have the divider in place between the rear seat and trunk and only helped marginally. Any tips on quieting it down that does not include exhaust? That seems to be good right now.
#1953
Did you use Dynamat or Lizardskin or some other kind of noise suppression when you built the car? How are your door seals? Even if they are new doesn't necessarily mean that they are actually sealing. Try the dollar bill test. Use a bill between the seals on the door when closed. If it slides very easily then the seals
are not tight enough. |
The Following User Says Thank You to gtospieg For This Useful Post: | ||
#1954
I used sound deadener on everything that didn’t move. I got one think my gas tank rubs my trunk floor. I gotta look into that but if I hit anything in the road other than a small pothole it sounds like I hit a speed bump at 70. Mindy it doesn’t feel this way it just sounds that way
#1955
![]() Quote:
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
#1956
Swapping out springs today. Will post pics when it’s done and will be posting old springs up for sale .
#1957
I used Kilmat and the pad and it's fine.
#1958
I can actually get a jack under it now!
#1959
Nice !
Looks good! Did you measure before and after fender lip to wheel center?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
